Shifting issues
Shifting issues
Have any other new 2019 RRX owners noticed any rough shifting in the lower gears? Mine has a “stutter” when upshifting through the first couple lower gears when taking off from a stop. Took it into the dealer, they agreed it was not smooth but don’t have a fix at the moment. The demo unit at the dealer does the same thing. Hopefully a software update soon to smooth this out? Not what you would expect with a new car.
Same problem here. Noticed it when shifting between 2 and 3 on a consistent basis. However, if you floor it - it transitions smoothly. Weird. I also had the dealer check it out. They said it was consistent with how the other 2019 RDXs were behaving. No fix available...
FYI...
FYI...
It looks like you guys are not the only ones experiencing this issue.
Hard Shifting 2nd to 3rd
2019 RDX rough shifts?
From Car and Driver's long-term test of the new Accord:
"Nearly every logbook comment so far has called out the 10-speed for faltering and stumbling between first, second, and third gears, especially when attempting to navigate a low-speed crawl. "
Been looking at the Accord forums.....
https://www.driveaccord.net/forums/2...eleration.html
Looks like some others are seeing issues also.
"I was reading an article the other day about the development of the latest multi-speed automatic transmissions including Honda's 10AT. One of the advantages that was mentioned in the article is that with so many gear ratios spaced so closely together, the torque converter clutch can be applied shortly after the vehicle starts moving in 1st gear and can remain engaged as the transmission shifts. With the TCC applied, the torque converter is bypassed and the engine now has a direct mechanical connection to the wheels as the transmission applies and releases various combinations of clutches and brakes on the planetary gearsets to shift through the various gear ratios. This more direct connection could certainly explain why the 10AT tends to feel a bit jerky in lower gears at lower speeds sometimes because it's acting more like a manual. The advantage to keeping the TCC applied is improved fuel economy because the torque converter isn't slipping which generates waste heat."
Sounds like it could be by design?
I skimmed through that forum and saw this post, which I found interesting:
Smoother in "comfort mode" with a light right foot, than in "sport" mode with a heavy foot. Shocking, I know.
I'd say it's not perfect, but still a whole lot better than the ZF 9-speed. The 6-speed Honda AT in our 2014 MDX is smoother.
But the fury unleashed with a firm stomp is quite satisfying.
But back in '14 there wasn't as much pressure to improve mileage. Manufacturers are trying everything they can to eke out every 1/10 MPG they possible can and, unfortunately, some of those solutions are having a negative impact on driving dynamics - sucks but that's the way it is and it won't be getting better.
The interesting thing is that the Honda 6-speed is a "Hondamatic" design, essentially a robotically shifted manual transmission with an added torque converter to smooth things out. Whereas the Honda 10-speed is Honda's first "conventional" planetary gear transmission, which typically have independent clutches for each gear cluster, and it also has a lock-up torque converter. AFAIK planetary gear transmissions have the potential to be smoother than robotized manuals, depending on how the controls for the clutches are tuned.
So I think the comment about locking up the torque converter and keeping it locked during low-load shifting is quite interesting. That would be causing the transmission to behave more like a dual-clutch transmission ( which typically don't have a torque converter ). DCTs aren't known for their low-speed smoothness, but they are known for fuel economy.
But the whole drivetrain is different than the 2014 MDX. The torquey turbo I4 in 2019 RDX is fine with grunting it out at low rpm. The MDX's V6 is more effective in the middle rpm range. The transmissions are tuned around those engine characteristics.
THIS is exactly why I waited to purchase a first year model.
If the jerkiness on the new RDX is worse than the 2018 Acura TLX 4 cyl DCT, then this kills it for me. The ZF9 jerkiness is intolerable, and the TLX 8 speed DCT is my benchmark for tolerability.
As I've mentioned on previous posts, I'd have both a TLX SHAWD Advance and MDX SHAWD Tech in my garage, but do not solely due to the jerky ZF9 speed.
I'm starting to regret not getting a 2018 RDX AWD Advance when I had the chance.
Right now the only new Acura vehicle presently made that I would be willing to purchase is the MDX Sport Hybrid Tech, but Acura choose to make very little of those, so actually getting one is impractical and unrealistic.
Disappointed with Acura. I'm getting tired of waiting. I really want Acura to succeed.
R. White (07-02-2018)
I got roughly 24MPG driving from Houston to Dallas and back, averaging about 75 mph in comfort mode, if that is any indication. If you are looking for mileage, the RDX is not for you.
The following 8 users liked this post by catbert430:
a35tl (07-04-2018),
AZ4035 (02-08-2019),
birdonamission (07-02-2018),
GW208 (07-02-2018),
Outfitter (07-02-2018),
and 3 others liked this post.
A deal-breaker is a deal-breaker, no matter what something someone is obsessing over (the "disappointing" mileage numbers; the Advance interwoven wheels; the "complicated" TTI; the "shocking" departure from a stick shifter to a push-button gear selector; and, oh, no, not the "super-ginormous" YUGE drive mode turn knob -- it is a travesty, the size of that thing). What else? Oh, yeah, the non-existent power-folding side view mirrors (wait, not a one of these, nor a combination of any of them, are "deal-breakers" for me)...
i am sure you can still find one. Look on Car JoJo
Like I said, something to the same effect, before -- somewhere around these parts in another thread -- if you're super focused on mileage numbers and fuel efficiency and the RDX's numbers bring tears to your eyes, get a Leaf!
The following 2 users liked this post by Madd Dog:
steve_97060 (07-02-2018)
I listed the things people have been complaining about in my post totally tongue in cheek. I personally have no problem with any of the things listed on there.
Yeah, I know...my sense of humor. Very special, sometimes. Ha ha.
Yeah, I sure hope I never sprain the index finger on my right hand. Would not be able to start the car, turn off start/stop, change gears, or use the infotainment system.
Oh, man... There are so many things you can't do if you have a sprained right index finger. The list is too long.
I actually see very little "pissing and moaning", but rather people noting some roughness in shifting and asking others if they have noted the same.
Most may recall the TLX in 14/15, the few who early on mentioned a rough shift got shit all over for not loving the car. We all know who that turned out. I am in no way suggesting that the 10 speed and the ZF9 are in any way comparable.
When I test drove the TLX it was immediately obvious the poor shifting and long delay in downshifting. The test drives that I have taken with the RDX showed little/no shifting issues. I thought that it drove very well, although my first test drive has ASS engaged, and the first thing that I did on the next test drive was to turn it off.
I personally welcome objective input from owners AND those who have test driven the car so that I can judge for myself.
The following 2 users liked this post by quantum7:
BruceLandry1 (07-03-2018),
HotRodW (07-02-2018)
I wish that the MPG were a little better for highway, but it is a lot of fun to drive, so I guess we have to pay a little for the fun factor and the immediate torque.
dont worry though, if you have an advanced you can cut off your hand and still open the tail gate. Just cut off your ears too so the moan doesn’t annoy you
I wonder if the shifting issues are related to trying to do too much with one transmission. Since the car has four driving modes, that means you may have 40 different shifting points. That seems like a lot of possibilities for something to go wrong.
