Seat position memory not working (I think)
Old Oct 1, 2024 | 08:12 PM
MarathonMax's Avatar
I own a RDX 2024 and I get the feeling that the adjustments I am trying to do since initially setting it up are not memorized. After doing the new fittings, I press the lower button marked as Set and then my position. I hear a qui k two bips that is sort of confirming that it saved the settings. Yet the next time that I drive my car after my wife, I do not have that feeling. Does this happen to you?
Old Oct 1, 2024 | 08:44 PM
John from PA's Avatar
I’m re-quoting because I can barely read the original post due to text color “I own a RDX 2024 and I get the feeling that the adjustments I am trying to do since initially setting it up are not memorized. After doing the new fittings, I press the lower button marked as Set and then my position. I hear a qui k two bips that is sort of confirming that it saved the settings. Yet the next time that I drive my car after my wife, I do not have that feeling. Does this happen to you?”
The fobs are numbered so let’s assume that fob #1 is for you. Try this, get the seat, mirrors etc, adjusted as desired for driver 1. With only fob #1 in the car, push the SET button on the driver door panel. You should see blinking green lights underneath the memory buttons numbered 1 and 2. Within 5 seconds, push button #1. The blinking should stop and your preference will be saved. Remove fob #1 from the car and repeat for fob #2 having your wife adjust all the desired settings.
One more thing, the rear view mirrors can be programmed to a desired down angle for backing up. Push the mirror selector switch to the laft, adjust the left mirror, then put the switch in the right position, adjust the right mirror. Then put the switch in the middle and adjust the mirror. THEN pair the fob to the car as outlined above.
RDXSpaguy7
3G RDX Problems & Fixes
Jun 30, 2022 02:17 PM
Gadgetjq
2G RDX DIY & FAQ
Nov 24, 2019 05:12 PM
403 UA6
Feb 28, 2011 06:43 AM
Mr.Tea
Feb 5, 2011 10:12 PM
mj31
Mar 11, 2005 09:54 AM
