Resetting TPMS
Resetting TPMS
After setting your tire pressure to what you want, is there somewhere in the settings menu to click "Reset TPS"? I want the car to memorize the new pressures as the base pressure from which it will advise if it drops too much. I cannot find it in the settings menu or in the book. Thanks in advance.
bluntman72 (03-27-2019)
This vehicle has direct read TPMS, with physical sensors in the wheels.
Some other Honda vehicles use an indirect system based upon relative rotation speed of the wheel, and this must be calibrated to a particular pressure in the tires.
The system in 2019 RDX requires no calibration.
NeedsANewCar
1G TSX Problems & Fixes
04-02-2019 04:04 AM
Anthony Lynn Davis Jr.
03-25-2019 06:44 PM
