Replace Bumper Trim Garnish....how?
Old Nov 22, 2025 | 09:55 AM
digger884's Avatar
3rd Gear
So I hit a lightpole base and cracked this piece of plastic chrome. I am hoping I can just pop it out and replace as its only a $60 part. But I fear it may require removing the bumper. Anyone have any idea. Its a random little thing so no YT videos or any info from googling. The part appears to have tabs rather than screws, so I am hoping it can be remove from the front. I havne't had a chance to see if accessible from the back.
Thanks so much. See pictures.
Old Nov 23, 2025 | 02:50 PM
Djgrippz12's Avatar
This might help https://acurazine.com/forums/3g-rlx-...ulding-986603/
Old Nov 23, 2025 | 03:06 PM
digger884's Avatar
3rd Gear
Originally Posted by Djgrippz12
Thanks. But no explanation as to how he ended up repairing
Hoping I can do or maybe my mechanic to avoid dealer or body shop $$$
Old Dec 3, 2025 | 11:56 AM
Hawkins21's Avatar
just my observation, but judging by the picture of the part and the diagram its only held on by clips and should pop off. I would use a plastic pry tool and rag and start on the top pulling toward you. use a second pry tool once its started and work around the front left side of it. i mean even if it breaks should not be an issue lol. you should def be able to do yourself, a shop is gonna either gonna take off the bumper (2 hour job) or charge you a full hour to do a 10 min job if it indeed just pops off.
Good luck!
Old Dec 5, 2025 | 10:52 PM
Optical Toxin's Avatar
You have to remove the bumper.
Old Dec 18, 2025 | 08:12 AM
hilde71's Avatar
Check out this guy's YouTube - he does a bunch of RDX repairs and across a few of the 'blue A-Spec' vids, he removes/dis-assembles/re-installs the front bumper, the trim pieces, etc. I've found them very informative and pretty fun to watch -
Old Dec 18, 2025 | 08:42 AM
hilde71's Avatar
Also, if you are a FaceBook user, search for this guy "Menn Boun" - he did a front bumper removal to install a lip on his blue RDX and went thru that trim removal (and it was tough). I think there are two hidden clips that make 'easy and intact' removal nearly impossible - but it yours is broken already, it might not be too bad. Installing a new one looks easy enough, though.
Old Dec 20, 2025 | 03:50 PM
hilde71's Avatar
This guy struggles with it, too ...
moose66
3G RLX (2013+)
Nov 23, 2025 03:05 PM
Dreux
5G TLX Problems & Fixes
Nov 2, 2020 05:53 PM
Johnyellow
3G MDX (2014-2020)
May 24, 2019 08:01 AM
TampaRLX-SH
Jan 11, 2018 09:03 PM
Ryan Williamson
Jan 30, 2017 02:19 PM
