Reboot the infotainment system ?
Old Mar 8, 2019 | 04:40 PM
  #41
STL_MO's Avatar
3rd Gear
So, I just tried three button reboot and now it's turning off with the car on/off.
But SiriusXM is GONE now ... I couldn't find it. This is not what I was expecting from a luxury car brand. Any recommendations?
Old Mar 8, 2019 | 04:51 PM
  #42
JB in AZ's Avatar
It has been reported this may happen. reboot again.
Old Mar 8, 2019 | 10:28 PM
  #43
STL_MO's Avatar
3rd Gear
Thank you! I rebooted again and everything looks good now.
Old Apr 23, 2019 | 12:44 PM
  #44
bahgee's Avatar
Got stuck on the disclaimer screen today. Nothing would turn it off. Not even the 3 button trick would work. Ended up having to pull the fuse. It sparked a little while putting it back in. Is this normal? Can I blow the fuse this way?
Old Apr 23, 2019 | 12:50 PM
  #45
securityguy's Avatar
You should be fine if everything is working. You can only blow the fuse if you short it out. You'll know if a fuse is blown...something will not work...period.
Old Apr 23, 2019 | 04:13 PM
  #46
bahgee's Avatar
Same thing happened to my RDX as well. And I couldn't turn off the system, I couldn't do anything and unfortunately I wasn't aware about the three button system reboot as well. So I just turned the display off from the setting menu and turned off the car. Will try this three button reboot in the evening today. Hope this works.
How did you turn off the display from the settings menu if the system was stuck on? Were you able to navigate the menu options?
Old Apr 23, 2019 | 04:16 PM
  #47
bahgee's Avatar
I have remote start (via keyfob). I will stop using it to see if that makes a difference. I believe it may the culprit since the screen is off while engine started, and then when you press the start button, the screen boots up. I think my screen has only frozen when using remote start.
macura22
3G RDX Problems & Fixes
240
May 5, 2023 06:12 PM
AcuraGuy2016
3G RLX (2013+)
18
Jul 22, 2019 10:45 AM
jcardona1
3G RDX (2019+)
61
Jun 11, 2018 04:19 PM
AWSb
3G RLX Audio, Bluetooth, Electronics & Navigation
May 23, 2018 05:30 PM
AdvanceMDX
3G MDX (2014-2020)
21
Apr 4, 2014 08:17 AM
