Rear Vents
Old Jun 20, 2018 | 04:08 PM
Joe256's Avatar
Rear Vents
Passengers are getting warm in back. I noticed no air flow from the rear vents. The owner's manual shows a vertical wheel between the two vents and states to turn it to change air flow. I have no wheel between the vents or anywhere! How do I get some air flow out of these vents?
Old Jun 20, 2018 | 04:10 PM
acuraada's Avatar
Which package did you get? I would try to manually up the AC, vent from outside, or vent inside with full auto. Better yet, call up your service manager!
Old Jun 20, 2018 | 04:21 PM
Joe256's Avatar
I have Nav. package. I have tried to adjust air manually, but no help. I will check with service, but before they say they have no idea, thought I would check here first. Do you have a wheel to adjust air flow?
Old Jun 20, 2018 | 04:57 PM
NightWriter's Avatar
Mine work. Note that when slid to the extreme left position, they cut off the air (and you'll see the vertical slats are closed off).
Old Jun 20, 2018 | 05:02 PM
pnoi521's Avatar
Registered TL Owner
The manual also shows that the back seats can recline and move forward/backward, however they don’t in my A-Spec and I doubt they do in the Advance. I’m wondering if they slipped a page from the MDX in there.
Old Jun 20, 2018 | 05:49 PM
acuraada's Avatar
must be a 2020 feature.
Old Jun 20, 2018 | 06:22 PM
Joe256's Avatar
Thanks NightWriter. I did try moving the tabs up/down, but probably not right/left. That's what I get for reading the manual. I will try tomorrow.
Old Jun 20, 2018 | 10:41 PM
burn1010's Avatar
Not to switch topics but do the front center vents have any sort of open close feature like the rear vents. I dont see dials. In my TLX its annoying that I cant close the front center vents. I rented an elantra and it had open close dials on the front center vents.
Old Jun 21, 2018 | 12:14 AM
Wander's Avatar
I discovered this the old fashioned way... fiddling around with it. But that highly magnified view reveals little emblems on the vent tabs that were probably intended to aid those who are inclined to read instructions. And who have really good close-up vision!
Old Jun 21, 2018 | 12:31 AM
Wander's Avatar
Side dash vents have dials to close them off. The center dash vents don't, but they can be directed pretty far toward the center.
OTHREETLS
Aug 2, 2017 04:41 PM
2002 3.2 CL
Aug 11, 2001 06:31 AM
JZ
Jun 22, 2001 03:48 AM
trippin555
May 20, 2001 03:38 PM
mgs333
Mar 29, 2001 09:43 PM
