massive hesitation on acceleration after braking is driving me NUTS !!
#161
I really believe Acura has refined the setup on 2020. My car is 2019, but after some firmware updates, it drives better in all aspects. The delay is still there, but throttle response is improved in both Comfort and Sport modes, so at least the car feels more responsive.
#162
I found A88 became available in Aug/Sep 2019 timeframe, judging by Hondata Flashpro Manager changelog and one of the TSB. The first version is A86, and the latest firmware version is A89. I know there exists A87, but cannot figure out when it was published.
So depending on when you did the TSB, yours might stay at A86 or move to A87.
#163
I did the same TSB, but in October. When did you do yours? I suspect the TSB also pulled in the latest ECU firmware in the HDS (diagnosis computer) database. Iny case, that should be version A88 (A8x is for non-Advance SH-AWD models). It is alao possible that the mechanic updated more stuffs than specified in the TSB. ..
Supposedly KTuner/FlasgPro are always based on the latest firmware version made available by Honda. I would like to see 19 owner who bought KTuner/FlashPro try the stock-equivalent "tune" first, and see if there is any difference, before going stage1/2.
#164
Expanse me
#165
37805-5YF-Axx. The first digit after A indicates SH-AWD/Advance, the last digit is firmware revision.
KTuner changelog has very limited info for RDX, so hard to know for sure which version KTuner flash would be based on.
I noticed lower piped-in engine noise, slightly firmer steering, much better balance (less understeer), and better throttle response (less low-speed damping).
#166
Expanse me
Open your hood and locate the ECU, the part number would be
#167
#168
![](https://cimg5.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1504/pcu_8749c33cd689cda9130eea0f879fd5348cb3182e.jpg)
![](https://cimg8.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1504/pcu_label_8e0cafc721f3b50da89107fafe341fdc825feb68.jpg)
#170
Thanks Wander for the detailed instructions. I found mine is A87, and my car was built in 11/2018.
#171
I bought a used 2019 White RDX A-spec last month. I notice the lag everyday now. Its not a Turbo lag as the RDX turbo is designed to build boost at low RPMs. It happens when you hard brake in to a turn and then accelerate out of it. Or when you just hard brake and jump right back on the gas. Definitely seems to be a downshifting lag as if the car doesn't know what gear to be in until you step back on the throttle. I have noticed that if you blip the downshift paddle and do a double down shift while breaking and before accelerating, it seems to fix this issue as you are actively giving the transmission input.
When I first noticed it I was making a left hand turn across traffic and genuinely thought I was about to broadsided by a truck. The delay can be about 1.5 - 2 secs. Coming from a 2012 WRX Manual and having full control over the car, this seems like an eternity to me and is very disappointing. I'm not sure how any engineer at Acura could find this acceptable when testing the car.
Not sure who one can contact about this and petition for a firmware update, but I would imagine its very fixable.
Other than this annoying feature, I am really enjoying the car. It feels every bit as fast and planted as my WRX did when I was just driving around having fun. The feeling is just much smoother and more refined compared to the WRX- which drove like a chained up beast. I will probably invest in a KTuner V2 so I can unleash a little more potential. And if we are stuck with this annoying lag, then anything that will help the car get up and go in traffic is definitely needed.
Funz51 (10-26-2019)
#172
Expanse me
#173
#175
I have an Audi A4. In the process of getting an RDX for the wife so I'm on here learning things. :-)
So we have a similar complaint on the A4. We do have a DCT so that part is different. It is a 2.0 turbo.
Taking away the DCT trying to figure out what gear to be in, there is a built in throttle lag. That sounds like the same thing here. I bet it's all about fuel economy forced on the the government.
For us switching into S mode takes it away and keeps the tranny in a higher gear so it can be shown that it's built in to the ECU. But S mode keeps us in a higher gear or two all the time and that can kill MPG.
Any way some reading can be done here. https://www.audiworld.com/forums/a4-...e-lag-2938803/
And some people have bought a pedal commander to fix it. They do make one for the RDX here. https://pedalcommander.com/products/...x~rk_base~qj_2
It shows being $299 for the RDX. and wires right in so it can be removed easily.
Anywho just some info for you frustrated guys....
#176
#177
Expanse me
No it isn't. The pedal commander changes the signal from the throttle so the ECU sees a higher voltage.
try this:
"Have you tried the reset throttle map trick (push accelerator down with car off, keep it down while pressing start button without starting engine, turn off)? It works for me, it usually takes 1-2 weeks before the throttle map reverts to that anemic feeling when you floor it and nothing happens for a full second. I simply repeat this process, it works and it's free." - from the A4 forum which complains about the same things we do WRT the throttle.
I just read this going thru the links provided by gooberman. I have not tried this yet. I probably am not a good candidate cuz I just burned stage 2 ktune,,
BTW, I will report on the stage 2 burn soon, including MPG, butt-kick measurement, rpm hanging and general 'normal' driving experience (traffic and otherwise). So far, with only some tooling around and a few WOT's, I find it awesome. Not only the power increase, but the way it handles itself with normal launches from 0, 10, and 30 mph. Very well done so far.
try this:
#178
try this:
try this:
Does the Ktune come with the tune, or is there something else to purchase?
Does the Ktune stay attached, or only long enough to complete the flash?
#179
Expanse me
I was confused with the process also. I purchased the V1.2, so here is what I know.
1) buy the Ktuner V1.2 from a dealer. they are all the same price. I got mine from PRL Motosports. They have so far been very helpful and had minimum shipping, and have a good reputation AFAIK.
2) get a Windows laptop. I used a Mac with Parallels loaded, which essentially runs windows on a mac (very quickly BTW).
3) download the ktuner software, register, and follow some instructions . I looked up a couple youtube vids that were good. here is a one.
A laptop is required to get you going- to 1) register 2) download the staged burns 1 and 2 (updates) from the ktuner site to your laptop, and 3) burn the tune to your car . 4) optionally record data from your RDX. I flash in about 4-5 minutes. Ktune unit only stays attached while you burn.
Now, you can, and I did easily, 'upload' (load from the laptop to the Ktuner OBD unit) the stage1 ,2 and factory tunes. They will stay there, you can add a couple more custom tunes if you desire. These tunes are only used to upload into the vehicle via the tunerView android app. I have chosen, at this point, to just burn a tune with my laptop. it is easy. Also, I already have a couple apps for my IOS phone that works well in case I want to see car info.
The ktuner Tunerview app (they developed it) will cost you a few bucks and be used on an android tablet or phone. In order to use it, you keep the ktuner plugged in, and it transmits data via bluetooth to the tablet/phone app. and as I said, you can burn your saved tunes right from the app.
Hope I answered some of your ?'s
ULEWZ (10-29-2019)
#180
Gearhead
For the KTuner, you will need it to download the tune from the Internet. Once it rewrites the software in your ECU you can remove it. The tune is stored in non-volatile flash memory so it is stored even the car is turned off. In the same place as the original factory tune. Think of it as updating your computer to new version of WIndows or a new macOS.
It stays there until you overwrite it with a new tune or put it back to the stock tune. The stock tune is saved during the initial install process and you can put it back any time.
ULEWZ (10-29-2019)
#181
Gearhead
https://www.youtube.com/watch?v=Y0kVUHhfMgc
Please just borrow some friend who has a Window's laptop and use it to the load the tune. Make sure it doesn't go into sleep mode while loading the tune. Again this can be an issue. Anything this critical use the original platform (Windows) that the software was written on to load the tune. I once had to bail out a client when their engineer decided to use a Mac running Parallels to load a new version of software on the engine control system for a very large jet engine. They flew to the middle of nowhere at a huge cost to fix it.
What the engineer said was it worked before. It was a 200k mistake for them not to mention several days of downtime which cost them probably millions when this engine was offline.
#182
Expanse me
I would strongly encourage anyone doing any sort of tuning, to not use something like Parallels when using software originally written for Windows to allow it to run on a Mac. While it doesn't happen all the time, there is a chance that there can be an issue with the USB ports. If loading the tune doesn't go as planned (let's say a USB hiccup) then there is a very real chance that you will corrupt the tune in the ECU and the car won't run. Maybe you can recover or maybe you'll need to buy a new ECU and start over.
#183
Do you guys also experience the delay on highway when you want to pass? It happens when I floor the accelerator at 50mph-ish, merging or passing. It does feel good when the power catches up, not fun with the delay at all.
#184
these days, Parallels looks really stable. Old versions were flaky. Also, do not use VIrtualBox as an emulator.. that WILL brick it. I tried that first and had a heck of a time with the USB ports being stable, and I know what I am doing.... POCrap since Oracle bought them... But, as you saw in my post, I suggested a Windows laptop, and still suggest it. If you do borrow someone else's laptop just to burn a tune, you can use another laptop later to reburn. You are not tied to one laptop.
As always, MAKE A BACKUP before you do anything like this. Make more than one if it's your primary computer.
Funz51 (10-30-2019)
#185
Happens to me anytime I mash the gas pedal. There’s probably a trick to it or something like downshift manually so you don’t have to mash the pedal or perhaps switch to sport+. I haven’t tried any of those though.
#186
I think we need to do a better job specifically describing the problem and our experiences. When people refer to turbo lag it is more the uneven distribution of tq/hp through the rpm range associated with turbo spool. Historically vehicles with single larger turbos that are tuned for peak hp/tq they will have dead spots in the power band where the low rpms or mid rpms will feel like a much slower car then the turbos kick in and punch you in the stomach.
The issue here or at least that I experienced on 3 different RDX test drives is the delay of any power upon initial application of the gas pedal. It happened after a cold start and warmed up just driving around the city under 40 mph. When getting to a traffic light or in a a suicide lane and you want to turn left against traffic to either make a U turn or an adjoining road I would hit the gas pedal it and would be almost 2 Mississippi’s before you would get response. When you have small windows that you can turn against traffic on a 2-3 lane road this is extremely frustrating, dangerous, inspires a lack of confidence.
The issue wasn’t in 0-60 times or 5-60 times or passing on the interstate or straight line speed. It was the initial response to the application of gas/throttle that was beyond frustrating; at least in my experience.
wsw (11-01-2020)
#187
Expanse me
The shifts feel tighter, the throttle responds faster, and 'smarter', if that makes sense.
#192
Expanse me
also try this:
car off, mash the accelerator to the ground and hold it there. hit your start button twice to turn on, sit a couple seconds and turn off the car. Then foot off the accelerator. Start car normally. See if that helps.
#193
Why wouldn't acura update ECU software to help with hesitation issue?
Is it because its not a software issue? If its a simple
update, I am sure we would have seen a TSB by this time
#194
Expanse me
We all have been asking that question for a year. Maybe its the required gov't requirement, or something else. They could just buy a ktuner or hondata software, look at the map, and adjust accordingly and conservatively. Its nothing proprietary.
#195
I only saw one person saying that its 90% gone. Is it really
gone?
#197
Governments are forcing it on manufactures and also buyer pressure to get a car that has good MPG.
One way of helping the numbers is to build in a "lag" so it doesn't ruin said numbers. Just like the stupid auto stop/start.
#198
I drove my wife's '15 Ford Escape Titanium FWD with 1.6L Turbo and 6 speed auto last night, after not having driven it in some time. It seemed to have much more "tip-in" (I think that is what it is called) than the RDX. It could just be a different throttle setting, as it does have much less torque and horse power, but less pedal for what seemed like better initial response. Getting up to speed on freeway was obviously much slower than the RDX. From a dead stop, or the scenario that has been mentioned here, no lag, or hesitation. I was again impressed, and remember why we bought it almost 5 years ago.
Memory seats, hands free tailgate, but no ventilated seats or Android Auto........Oh yeah........
And it is a Ford...But, it has been very reliable...
Perhaps I don't drive under the conditions that have been cited here...so I can't say I have experienced the hesitation on my RDX...
#199
Gearhead
The initial slowness is still there tuned. Easy way to prove that, is brake torque it while stopped and see if you get any boost. The same thing limiting that behavior is likely the same nanny keeping it from having full torque to the tranny.
As for improvement, don't just rely on the butt dyno. Go slap some timing gear on it and see how it runs yourself. Yes, the tuned car is quicker to 60 but 0-5 mph it is the same as stock.
#200
Expanse me
it isn't the boost that delays it. It could easily put it in gear faster.
...opinion...
