Keyless entry reset
Old Jul 14, 2025 | 09:26 PM
Mini RDX's Avatar
Keyless entry reset
Does anyone know there's a way to reset the keyless or smart entry? Car battery died. Keyless entry worked before it died. The key fob will unlock the car and recognizes it to start but attempting keyless lock or unlock doesn't do anything. Settings don't seem to do anything. I do have an iHDS and Launch programmer which has the immobilizer listed but am reluctant to reset using it. I tried every setting that I can find.
Old Jul 15, 2025 | 07:08 AM
RDX-Rick's Avatar
It doesn't sound like you have a problem with the fob, since the engine starts. That also eliminates the immobilizer as being the cause of the problem.
Each of the 5 doors has an antenna which transmits a signal a limited distance (perhaps 3 feet). Have you tested if all 5 doors are not working. Possibly the fuse that powers the system has blown.
Also keyless entry does not work if the fob is within about 6 inches of your cell phone. Have you tested this at a different location in case there is some radio frequency interference at your home, for example a noisy CFL or LED bulb in your garage door opener, or a HAM radio operator next door.
Old Jul 21, 2025 | 07:03 AM
John from PA's Avatar
There is a fob reprogramming sequence on a dealer website. Unfortunately it isn;t real clear as to the model year and model to which it applies. See key for reprogramming
Juice-D
Nov 23, 2021 03:40 PM
9632tl
1G TL (1996-1998)
Oct 17, 2010 08:17 PM
akatypes
Feb 3, 2009 11:49 AM
EPS CL
Aug 4, 2008 11:34 AM
XJGrl
Aug 13, 2006 07:47 PM
