View Poll Results: would you buy sway bar set for your RDX?
Yes
![](https://acurazine.com/forums/images/maestro/polls/bar2-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar2.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar2-r.gif)
![](https://acurazine.com/forums/clear.gif)
20.00%
No
![](https://acurazine.com/forums/images/maestro/polls/bar3-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3-r.gif)
20
80.00%
Voters: 25. You may not vote on this poll
how many of you would buy Anti sway bars?
Just trying to take a count here of the interest for this? maybe eibach can make a small batch to go with the lowering springs? I know I would definitely buy a set, ive done this to all my cars ive owned, in fact this is the first mode I do.
justnspace (07-22-2020)
Honestly, I used to do this mod, but I am no longer interested in "messing" with what the manufacturer has done in regards to R&D. The best compromise of ride handling etc. I'm good just as it is, the RDX is a fine ride for me.
Obviously, not all agree, which is great!
Not interested.
hans471 (07-22-2020)
Maybe to a rear sway bar - wouldn't mind slightly perkier turn-in but not a ton.
I'm more interested in better shocks as I find the damping to be not good enough (too stiff legged) - a set of Koni sports would sure be nice.
As for stiffer sway bars, I went that route long ago with my '84 Prelude, along with wider, lower profile wheels and tires, and it cornered like it was on rails until one of the sway bar brackets broke from the added stress. This was within the car's first couple years of life. I vaguely recall getting an indy shop to weld something near the gas tank to fix it. They drained the tank, stuffed a couple rags in the opening, and went at it. I didn't watch.
Also, I seem to recall the steering got really heavy after the mod, but that might have been from wider wheels and/or inappropriate offset. I didn't have a clue what I was doing at the time. Pretty much I still don't, so I try to buy well engineered cars that suit my needs and resist the urge to screw them up.
2020 RDX White/Espresso
I don’t know about sway bars specifically, but I don’t buy into this idea that the “manufacturer has achieved the best balance” anymore. It’s clear that most cars come with inherent compromises. Acura perhaps more so than other luxury brands if for no other reason than they are not offered with a huge list of expensive options. With the RDX it’s basically package one, package two, or package three. That keeps costs down and makes it a value, but it also means that there are improvements that could have been made that we’re not because they Acura’s neat little boxes. So those improvements have to come from the aftermarket.
So yeah, bring on the sway bars, ECU tune, catback exhaust, high flow fuel pumps, down pipes, inter coolers and all that. Until there’s a factory tuner option, there’s Graham Rahal!
![Devil grin](https://acurazine.com/forums/images/smilies/devilgrin.gif)
I bought the Advanced model to get the upgraded suspension among other things. This car handles better than I drive so why would I want to modify it and spend more money? If I wanted better handling I would have bought the "Z".
Are you in an A-spec? I'm wondering if your problem isn't the Goodyear tires. If my Advance turned in any more crisply I'd be spinning donuts.
Yeah, I'm in an A-Spec and the tires are indeed hot garbage (will replace them next Spring when I'm driving more). I generally like pretty pointy front ends on my cars - my Miatas and my TSX all got stiffer rears bar. I'm sure if I were driving something mid engined that wouldn't make the mod but for a FWD car I definitely want a bit of extra rotation on turn in.
No fancy wheels on this one, either, cuz it was a replacement for the Prelude that got stolen and totaled because of the flashy wheels. Sob. It died much too young.
![Bawling](https://acurazine.com/forums/images/smilies/bawling.gif)
But the MR-2 was absolutely useless in the snow. I recall trying to make it home to the burbs in Boston after a snowstorm and I couldn't make the darn thing track a sweeping banked curve on a neighborhood street, so I finally flipped it around and drove backwards for about a quarter mile, with the tail angled about 30° up the slope. No joke. I probably still had MN license plates, so no one got too worked up about it. Boston drivers are just a different kind of crazy. And the RWD BMWs weren't going anywhere.
With SH-AWD turn-in comes courtesy of your right foot, especially in sweepers. Just like your RWD Miatas. Dunno what FWD RDX feels like.
The car in A-spec + RS-A tires form needs more front-end grip more than anything else. I also think once the car gets over the initial understeer stage, the car actually rotates quite well, and if you make good use of SH-AWD, the factory setting kind of makes sense, because reducing the rear grip (yes that is what stiffer RSB does) is going to make the car too tail-happy for those unguarded.
I would sign up for a set of KW or any mono-tube ones....
mrgold35
I added the Progress RSB to my 08 RDX along with Eibach Springs. I've didn't notice a big improvement in cornering on the RDX like I did with my 06 TSX with A-Spec suspension+Progress RSB. I think the reason why is because sh-awd was doing its job. The difference I felt on my RDX was when I needed to corner without benefit of sh-awd. No engine power and OEM set-up and the RDX is close to a 2 ton top heavy CUV in the corners. Adding Eibach and Progress reduced body roll, squat, dive, and I was able to take corners at a much higher entry speeds off engine power. Higher entry speed, less power needed to maintain speed in/out of corner, and I my speed stays about the same without using the brakes or sh-awd as much.
Eibach springs might not work with the Adv RDX; but, the Progress RSB+active dampers might yield the same results folks will have with non-active damper+Eibach Springs+Progress RSB RDXs. I would do this mod if I had a 3rd Gen RDX because I like pushing the performance envelop.
The following 3 users liked this post by Madd Dog:
Summer is Coming
