Has anyone installed the Start-X remote starter?
Old Dec 12, 2023 | 10:19 PM
RA100524's Avatar
Has anyone installed the Start-X remote start? Looks to be plug and play by connecting to BCM
https://a.co/d/7l4u1SM
Old Dec 14, 2023 | 05:58 AM
rmeastma's Avatar
I tried to install it but it is very tight fit at the BCM and I for some reason could not get the BCM to unhook from its mount to gain better access. I got the first 3 plugs in after much fighting and the just could not get the last two to line up. I ended up throwing in the towel and returning it. If you can get the BCM off the mount it should be relatively easy install.
Old Dec 14, 2023 | 09:17 AM
RA100524's Avatar
where is the bcm in the rdx? Did they send any diagrams to help you see where it’s at or you found some online?
Old Dec 14, 2023 | 01:05 PM
rmeastma's Avatar
It is behind the driver side knee bolster left of the steering wheel shaft. It is hard to see and all work that I did, had to be done by feel only. IIRC I looked up pics of the BCM to see what it looked like then found it under the dash by looking up from the floor with a flashlight then felt the connections to feel that they matched the pics.
Old Dec 30, 2023 | 07:12 PM
bebo's Avatar
Nope
I am a handy man, and I installed many remote starts before for different cars, but I do not think it is an easy job as the BCM is hidden high behind th driver side and you have to unclip it to access the ports or do it blindly! so I went ahead, and I installed the factory remote and I programmed the Keys Fob with Launch tool.
Old Dec 30, 2023 | 08:32 PM
hidperf's Avatar
What's this Launch tool? Sounds like it may come in handy.
Old Dec 30, 2023 | 09:54 PM
bebo's Avatar
Launch Scanner
Launch pro 919X X431 OBD2 All System; it is Diagnostic Scanner Tool w 31 Services. Price goes from 350$ to 450$, I got mine open box for 250$. By this tool, You can activate 2 way communication and register a new Key Fob.
abbyzak
NY/NJ
Feb 2, 2012 04:41 PM
Elegant TYPE S
Nov 8, 2006 06:09 PM
dogfight
Feb 21, 2004 04:00 PM
30CL
Dec 28, 2001 11:49 PM
dyar1
Nov 25, 2001 12:02 AM
