Garage Door Opener
Old 03-11-2019, 09:20 AM
BadRobot65's Avatar
Garage Door Opener
After tryin all weekend to get my 2019 RDX to pair with my Chamberlain garage door Im not having any luck, any suggestions .
Thanks in advance
David
Old 03-11-2019, 09:36 AM
carson2246's Avatar
My dealer paired the opener which I was smart enough to take with us. I had to do the second step using the "learn" button on the garage opener at home. The owners manual steps worked for me. Believe there is also an Acura YouTube for this.
Old 03-11-2019, 09:37 AM
~HondaF1~
R J Poseidon 6's Avatar
Sell the house!
The following 5 users liked this post by R J Poseidon 6:
alpine909 (04-21-2019), AZ4035 (03-11-2019), Madd Dog (04-22-2019), NooYawkuh (03-11-2019), zroger73 (03-11-2019)
BadRobot65's Avatar
Smart Ass.
Old 03-11-2019, 09:50 AM
Midwestuser1's Avatar
Thanks in advance
David
First point the hand held garage opener at the Homelink button. Push & hold the button on the hand held and the button you want to learn underneath the mirror simultaneously. You should only need to do this for 5 seconds tops. Then go to the Garage opening unit in the garage and push the “learn” button. Then hussle back to the car and push & hold the same button you pointed the handheld remote at. The garage opener dome light should blink when it syncs with the homelink button in the car. Then do a quick test to ensure the homelink button now works.
Old 03-11-2019, 09:52 AM
BadRobot65's Avatar
Thanks you I will give that a try.
Old 03-11-2019, 09:59 AM
~HondaF1~
Just playin' man, I sincerely hope you get your issue resolved.
Happy Monday!
Old 03-11-2019, 10:00 AM
BadRobot65's Avatar
Thank You , Happy Monday to U
Old 03-11-2019, 10:11 AM
flames9's Avatar
If you go onto youtube you can find out how to do. They are all basically the same..some u need to use the hand held garage door opener..hold it up to the mirror.....others u need to push the learn button on the actual garage door unit......ya it can be frustrating,lol.....and when u go and sell it..dont forget to wipe them clean!!
Old 03-11-2019, 11:29 AM
Skeptic
NooYawkuh's Avatar
It took me multiple tries with my Pilot and multiple tries with my RDX. I have a Genie with a rolling code.
Follow the procedure in the manual carefully and T O - T H E - L E T T E R .
Old 03-11-2019, 11:51 AM
BadRobot65's Avatar
Got on the first try this time, thanks for all the reply's
Old 03-11-2019, 01:34 PM
Gary From LA's Avatar
Thanks in advance
David
Hi, David!
I have the same issue with our old MDX - issue gets resolved after I install the fresh battery to the remote control. Hope this help.
Old 03-11-2019, 02:52 PM
zroger73's Avatar
On my 2011 Overhead Door (Genie) opener, I had to change the rolling code mode on my remote from CodeDodger 2 to the less-secure CodeDodger "1". HomeLink isn't compatible with the CodeDodger 2. Perhaps Chamberlain/LiftMaster requires a similar procedure?
Old 03-12-2019, 10:10 AM
DHood's Avatar
I have a realativity current LiftMaster by Chamberlain First try with just my Remote pointed at the Acura Mirror with the Remote Control Buttons.
You should only need to use the GDO Learn feature if the this does not work, - typically on older GDOs.
DavidH
Old 04-21-2019, 04:02 PM
scatterbrain's Avatar
@BadRobot65 - I sort of have the same problem with an old liftmaster remote and a 2019 TLX. Where did you hold the remote? It seems it doesn't matter where I hold the remote the slow flashing never changes (implying that it's not receiving the signal or something). I had the same sort of issue with a 2013 RDX a while back. I can't for the life of me understand why I can't get my remotes to work easily with Homelink. If someone has the magic position to where you hold the remote for programming, let me know. Once I get past that, the garage door "learning" process is actually the easiest part... but can't seem to get past the initial programming. -sigh-
Old 04-21-2019, 05:23 PM
BLEXV6's Avatar
I hear you, I also have the Genie with the rolling codes. The use of the remote to train my MDX did not work. I ended up driving into the garage, pressed the learn button on the door opener and it paired. Took about 10 annoying minutes.
Old 04-21-2019, 06:46 PM
Null and proud of it
Midnight Mystery's Avatar
You mean the garage door failed to open and you ran into it?
You parked in the garage to pair it, oh, ok...
Last edited by Midnight Mystery; 04-21-2019 at 06:47 PM. Reason: What is the purposs of this? Anyone?
Old 04-22-2019, 07:42 AM
BadRobot65's Avatar
I wasn't able to use the hand held remote for programming I just parked the RDX near the garage and went through the pairing procedure like the manual said. and it connected right away.
Old 04-22-2019, 10:27 AM
Coolguy's Avatar
I read on another forum that the Radar sensor was somehow interfering with Garage door radio signals .. I am yet to set it up .. will update back with my experience
Old 04-22-2019, 10:41 AM
zroger73's Avatar
Automotive radar systems operate at or above 24 GHz.
Garage door openers operate in the 315-390 MHz range - a much lower frequency.
The TPMS sensors on the RDX operate at 433 MHz and at a much lower power level than garage door opener remotes which have to transmit hundreds of feet rather than a few feet.
Old 04-22-2019, 10:45 AM
JB in AZ's Avatar
I have read (one example --> LED interference ) that if you have LED light bulbs (or even CFLs) in or near the garage, they MAY interfere with your GDO remote, both hand held and Homelink in car. Not verified, but something else to be aware of.
Old 04-22-2019, 10:56 AM
zroger73's Avatar
Definitely. It happened to me!
https://www.ridgelineownersclub.com/...ml#post3005314
I've also seen forum members post that certain dashcams reduced their GDO range.
Old 04-22-2019, 07:09 PM
anoop's Avatar
I was never able to get my BMW working so I didn't bother with the Acura. A friend that was visiting insisted on giving it a go and he was able to do it. I think because of timing it works best if you have 2 people working on it together, one inside the car and the other dealing with the garage's controls.
Old 04-22-2019, 07:20 PM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
Depending on your door opener, you may need a "Homelink kit" from Liftmaster/Chamberlain.
You can call Liftmaster and throw a fit and they'll probably send you the kit at no charge as the 2.0+Security is claimed to have homelink compatibility.
Old 04-22-2019, 09:24 PM
Catman70's Avatar
They actually sell LEDs that won’t interfere with the remotes. I bought them and they work great. Took me forever to figure out why my homelink and remotes only worked when they wanted to. Since changing the bulbs, they are flawless with good distance too.
Genie LED Garage Door Opener Light Bulb - 60 Watt (800 Lumens) - Made to Minimize Interference with Garage Door Openers (Compatible with All Major Garage Door Opener Brands) – LEDB1-R
Amazon Amazon
Old 04-29-2019, 09:20 AM
DHood's Avatar
Agree
Genie LED Garage Door Opener Light Bulb - 60 Watt (800 Lumens) - Made to Minimize Interference with Garage Door Openers (Compatible with All Major Garage Door Opener Brands) – LEDB1-R https://www.amazon.com/dp/B01IHHVZTW..._LANVCbJGN5GVM
I agree the Genie LEDs have been working for me without any problems
juicy
08-25-2001 06:17 AM
Quick Reply: Garage Door Opener
