Detailing the RDX - any tips or recommendations?
My 2020 RDX Advanced is in need of a detailing - I've done my two 4Runners in the past, but it has been some time since since then, but I am familiar with the steps. I've watched hundreds of youtube videos too, to refresh myself on the process.
I ordered a Griot's G8 DA and a bottle of the Perfecting Cream - I got the smaller 2-3 inch size because of some of the smaller more rounded and intricate sections of the RDX, but I do have some questions before giving this a go:
- Acura has soft paint. I tested some Meguiar's Ultimate Compound Polish on a small scratched up section of the roof and just rubbed it with my hand and a microfiber towel and I was able to make many of the scratches go away. Makes me think that with a DA, it will be quick work. What kind of pads would be recommended for this? I don't think I need anything very aggressive. I also will probably use the Ultimate Compound Polish and then finish with the Griot's Perfecting Cream I bought. I'm going to need two different sets of pads.
Any tips on how to deal with the many peaks and valleys on the outside of the RDX? For example, the hood has those two bowed ( ) lines...how do I deal with those when using the DA? I am afraid of burning paint. Also, the front left and right fender area...it has about a two inch bowed valley that leads to the tip/edge of the headlights. I'm not sure how to handles that. If I recall correctly, don't run parallel across a U shaped or bowed up/down area. Go up and down, perpendicular. If I am going to run over a line with my DA, or going to run across the painted area above the side car doors - just be quick about it and don't linger to avoid burning the paint. Right?
Any help before I take the plunge would be appreciated!
I haven't started correcting my paint yet since I ceramic coated my paint within a few months of ownership but its nearing the 2 years where the coating should be failing (CQuartz UK), the water beading is starting to fade and is sheeting a bit more and there are areas that will need to be wet sanded and corrected from daily driving and public parking. If I were you, I'd start with the least aggressive polish you have and start from there. The megs Ultimate compound polish I believe uses a diminishing abrasive which starts coarse and gets finer as you work it, that might be too harsh to start with. If you have a non diminishing light polish (Megs m201) I'd start with that and a foam polish pad with the DA and work on a section that's not too obvious if you work it too much. Using the 3 inch DA is a good idea for the sharp lines that the RDX has especially the section that's between the 2 body lines that runs down the side of the car but you'll prob want a 6 inch as well for the larger areas like the middle portion of the hood and bottom of the doors to save time. Worse comes to worse if the paint is still too soft for a strictly polish, then go with just water and a foam pad (trick I saw from Larry at AmmoNYC) but I doubt the paint is THAT soft.
Lemme know how it goes.
As for how you'd specifically polish the ridges, watch this video if you haven't before, the go real deep and technical in how to tackle ridges.
The entire video is a good watch too if you have the time.
RDX ILX TSX
I'd be curious to know how the G8 worked out for you; I've been thinking about this or the G9 but would love to hear the update and some photos! I had an old orbital polisher when I detailed my S2K but have heard some good things about Griot's...
It's a dual action random orbital polisher - or DA for short.
JB in AZ (01-18-2021)
Vince D (01-29-2021)
I'll be doing the full car sometime in the Spring, but more than likely will get a different type of polish like a Sonax perfect finish 4/6 and use the black pad with that... I think based on how soft the clear is, this combo should provide pretty great results. We have the Performance Red Aspec and imperfections are easy to see. Can't wait to correct it and coat with CQuartz UK 3.0. I've been pretty happy with that on my black A4 over the past 2 years.
