Can you Disable AWD or make it temp FWD? Spare tire
9th Gear
Thinking about rigging up a spare tire for my 2020 RDX A-SPEC SH-AWD. Wondering if I should invest in the kit.
I'm so confused, what are you actually asking?
9th Gear
Sorry my phone malfunctioned before i completed this post. I cant figure out how to edit delete the original.
I wanna know if i should even bother investing in a spare tire. The model we bought doesn't come with one. I'm assuming bc of our 20 inch wheels. If the manufacturer doesn't want us driving on mismatched wheels even for short distance like emergencies would call for then I'm not sure if I'm able to do this. So is there a way to put the car in a temporary limp mode. Maybe electronically shut the awd system dn for a bit or allow the computer to compensate for a different tire rpm due to different diameter.
Also how do i edit my original post? Lol sorry
mrgold35
It is A-OK to use the OEM donut spare for the RDX. Just follow the limitations in the owner's manual for driving with a donut spare. I use the donut spare with my 06 TSX and 08 RDX; but, have full size spares at home. I have Conti DWS 06 tires on my vehicles and it can be days or weeks before replacements are available depending on the time of year. I only use my donut spare until I can get home to replace with the full size spare or to the tire shop to fix the flat right away.
I don't know if the +19 RDX can fit a full size spare? Some 2nd Gen MDX owners had an issue fitting a full size spare when they had certain aftermarket hitches installed. Some stuck with the donut spare and other carried a 12v air pump and deflated the full size spare enough to fit between the aftermarket hitch arms.
Remember the 20inch aspec rim with tire is the same diameter as the 19inch rim with tire, it’s just the rim to tire ratio is different. I have the spare that I added to my aspec, I went with a slightly wider tire that caused the diameter to grow a slight amount because of the fixed rim size, it’s within 1% of the stock tire in diameter
Get the spare if you want. If you plan to travel anywhere you might not be near services, I recommend it.
Don't worry about the size mismatch. It won't hurt the AWD. If you're worried about it, keep your speed down while you're using the spare, which you should do anyway. And get it changed ASAP.
The "packaging" of spare with the different trims has nothing to do with different size wheels and protecting the AWD. Weight and cost come to mind.
And the mount points are different for the hoist on this vehicle vs previous models, so you can't cheat and use an old hoist.
Where was this attention to detail when they designed the infotainment system?
![Whistle](https://acurazine.com/forums/images/smilies/whistle.gif)
So unless you plan to lug the spare around on the roof or in the cargo area, no go.
robster80
08-11-2016 12:09 AM
08 NBP TL
09-27-2010 06:38 PM
