BG 44k fuel cleaner
BG 44k fuel cleaner
Any thoughts on running BG 44k fuel system cleaner in RDX every 15k miles
or so? Its sometimes recommended by Honda dealers, and someone just posted fuel injector cleaner recommendation in service manual for Canadian RDX.
From what I read BG 44k is professional grade stuff, but more expensive than techron.
Think dealers recommend it as an ……..UPSELL………PROFIT center.
Way more than TECHRON especially if you buy TECHRON at Costco in the 6 pack.
Amazon has BG44 at $25 per can. Years back BG really controlled their products to “make them more professional”.
hans471 (12-07-2021)
I just dump a bottle of Techron complete fuel system cleaner every few thousands miles and call it a day. I also occasionally put in a few ounces of Lucas fuel saver. I bought a gallon of it at Walmart and transfer it to a 4 oz bottle. The professional grade is more concentrated.
I was also reading that GDI engines might need injector cleaner more than previous generation (non GDI).
so probably a good idea to run once in a while
yep, I will probably use Techron next time. For a price of one BG 44k, I can get 4 techrons… I doubt BG 44k is 4 times better.
I've used many different cleaners, I don't notice a difference but I still do it anyway. I like Techron, Gumout Regane, Redline Cleaner and BG44k.
Folks, modern fuels do not require any additives, period, full stop, the end. Using Techron, BG 44, or any of the other products on the market will simply clean out your wallet and provide zero benefit to your car's fuel system or engine.
Waetherman (12-08-2021)
Most car makers recommend that for best results you should always use a high quality "Top Tier" fuel. I live in Louisville, KY and ALL the gasoline sold in this city comes from one source down at the river. It comes to all the stations in a generic truck. The fuel companies claim they put in their additive packages when the fuel is put in the truck. Flip a coin on that one.
Fuel additives don't hurt, unless they do. All have powerful chemicals in them and too much of a good thing can start to damage parts. I have seen people use these fuel cleaners full strength on parts that were very dirty only to have the metal actually dissolve after soaking all night. Of course in your fuel tank they are diluted. If you feel you need to use this stuff use it sparingly. Wait until your tank is nearly empty then add the proper amount (and a little extra is not good!) then fill up the tank so its well dissolved. Don't over do it.
As for BG products, I remember the salesmen coming in and making a big deal about how much extra profit the parts department could make putting it in people's cars. It was all about the $$$$. Not saying it works or not or is needed or not but their pitch was always about extra money.
JB in AZ (12-16-2021)
I call such assertions "urban legend". Why? Lots of folks want to believe fuel additives will clean the intake valve faces which are susceptible to being, for lack of a better term, "gunked" up. Here's the thing; with few exceptions (thinking some Toyota engines which feature injectors for both the combustion chamber AND the intake port), fuel, additive laden or not, NEVER comes into contact with the valve face, so you can dump as high a percentage of additives as you want, it won't do diddly-squat to clean the intake valves.
It's the chart I quoted in post #10.
https://acurazine.com/forums/third-g...minder-997015/
It used to be that Honda/Acura was not recommending fuel clean service, which was written in the manuals.
I scanned RDX manual, and this language is not there. They do however recommend Top Tier gas “ to avoid build-up of deposits”.
This is interesting as not everyone has access to Top Tier gas that is conveniently located.
if you use gas of questionable quality, nothing wrong with running good injector cleaner.
They do have their limits of what they can and can not do, and they are not for everyone and also depend on many factors.
Top tier gas is all marketing gimmick? What is your source for this info?
sorry, but I disagree. This is not black and white, fuel system cleaners have their limited use benefits.
As for a marketing gimmick; when Top Tier first hit the market, circa 2004(ish) I contacted several major fuel brands which were considered non-Top Tier (Exxon Mobile for example), and got similar response from all of them, "All of our gasoline fuels meet or exceed the Top Tier fuel requirements, however, we will not be licensing our fuels to be able to display Top Tier logo." With the above said, apparently the Top Tier marketing was so successful, literally every brand I contacted back then is now a subscriber to Top Tier; long story short, they caved.
We talking specifically about fuel system cleaners. The benefits are that they clean carbon deposits.
Its documented and also on youtube people compare cylinders heads before and after, also improved fuel economy was reported.
like I said before, it has its limits, and dont expect that one treatment will do magic. We have a lot of crappy gas stations like US gas and Global, that sell god knows what. Yeah, it has minimum government required stuff, but that might not be enough.
Here's the thing, anecdotal evidence like you're presenting doesn't prove anything. Over the years I've seen many worthless anecdotal evidence based assertions where folks seriously claim adding acetone, turpentine, and/or castor oil (or other elixir of choice) to their fuel resulted in dramatic and measurable fuel economy gains; I expect if you were to read such claims you'd dismiss them out of hand, and yet you hold on to the unproven claims of fuel additives. Why?
There are 75 years of miracles in can………claiming all sorts of benefits like increase power, 10-30 MPG increase, cleaning any and all parts of the engine,
Maybe magnets on the fuel line, moth balls in the tank, remember STP, Wynns, GUMOUT, some names still sold today.
Some of the all time favorites while these promise magic in the engine….over the years there 100’s promising fuel magic as well.
The following 3 users liked this post by Showkey:
no, not anecdotal evidence, people do testing and compare how much carbon was cleaned before and after, pictures of pistons heads. From my reading and watching project farm videos, fuel system cleaners do work, some better than others. If you dont believe it, its your choice.
I'm not advocating that, I'm just some schmuck on the internet; what I would strongly recommend is for you to do some research using resources which are vetted and up to date as possible. Start with the databases on sae.org and go from there.
horseshoez (12-15-2021)
Except I spent enough time researching fuel system cleaners and came to conclusion that they do work with some limited success. There is plenty of information from independent sources that confirm it. None of them claim it will do wonders, but does show some marginal improvement to clean carbon buildup. To each his own, if you have something against fuel cleaners, its fine with me, this thread was specifically for BG 44k, but it quickly turned into questioning all fuel cleaners, this is really not the purpose of this thread.
Vader101
10-28-2020 10:39 AM
crazyjkz
07-29-2010 09:19 AM
