ATF DW1 Vs. ATF Type 2 question?
I went to dealer parts department and asked for 5 quarts of Transmission Fluid for my 2019 RDX front wheel drive. I just realized he gave me Acura ATF DW1 instead of Acura ATF Type 2.0 as specified in the owner's manual. Is ATF DW1 an acceptable substitute?
Thanks!
Mario
Thanks!
Mario
The following 3 users liked this post by Dereileak:
Interesting. It seems ATF 2.0 is backwards compatible to a lot of stuff that used to recommend DW-1. Perhaps OP was given the fluid because Honda deems it an acceptable substitute when ATF 2.0 is not readily available?
I have a quart of Castrol Import Transmax (DW-1 compatible) that I may just throw in there to top up the 0.1qts during a transmission fluid change.
That's not how I read the chart.... It says that ATF 2.0 is meant for 2019+ RDX but 2018 and below utilize the existing DW-1.
zeta (10-19-2022)
I think the biggest difference might be viscosity differences, with a TSB released for the RLX about changing the ATF more frequently due to premature breakdown:
http://www.urvi.net/forumfiles/SB/B19-004.PDF
With how frequently I'll be changing the transmission fluid, 0.1qts will be a non-issue. Heck, I could probably start doing 10k mile changes with straight DW-1, or rather, a substitute and it wouldn't be an issue. Just swap the fluid out every other oil change ... an extra 10mins, if that. I won't, seeing as I bought a full case of ATF 2.0 a month ago, but I could probably get away with it.
