10 Speed Transmission=Turn off.
#81
Oh Mo,
I don’t need google to tell me how much I paid for the same transmission flush at an Acura dealer - it was significantly less than $350.
The other thing is, the ZF was a known dud before Acura even used it and was terrible right out of the gate (I really have no idea who at Honda green-lighted that one). As far as I know, this 10-speed has not had any reported issues yet.
Don’t knock something you haven’t tried.
#82
Wow! This is becoming an interesting topic. Just as interesting as a kid receiving their first new 10-speed. lol
"Do not attempt to check or change the automatic transmission fluid yourself." I hope this is an error or a mistake. Otherwise, we can assume this is code for voiding your transmission warranty if anyone other than the dealer touches the transmission? I can already hear the dealer's cash register gleefully ringing.
That being said, how would anyone know if your transmission fluid was replaced? Because the mark on the bolt is off? All you have to say is you know Honda has had issues in the past with transmissions and you wanted to be proactive so you took it to an independent shop to be replaced early. That won't void your warranty. You can replace the fluid every day and it won't void your warranty. You just need to be able to provide receipts and dates the work was done and that's it. You can even do it yourself, so long as you keep your receipts.
You would only risk losing warranty if you couldn't prove you had servicing done at the interval it is required. If you have the receipts and mileage written down, you're golden. This goes for any maintenance. Oil changes, coolant flush, brake fluid change, etc. You are not required to take your vehicle to a dealership.
#83
A couple years ago I remember Honda, along with a few other manufacturers, were getting annoyed that people were working on their own cars and wanted that option to be taken away from them. It's clear nothing ever came of that. However, I get the feeling that message in the owner's manual is just your typical legal jargon. Don't do this, don't do that, because the common owner is not all that in tune with anything car related. I consider it a blanket statement to cover themselves.
If/when I get the RDX, I will no doubt do the fluid replacement myself....but as you said, keep a log of the work and keep the receipts.
#84
FWIW I mostly commented on the Owner's Manual RE: ATF because in past vehicles it has usually had a section on how to check ATF level with the dipstick. On the ZF 9-speed and Honda 10-speed there ain't no dipstick. In the case of the ZF that may be partially because the darn fluid expands so much with temperature, but I think that unit is also a princess that is easily flustered by fluid contamination. The Honda 10-speed may also be sensitive to contamination. Dunno.
#85
Cajun Gumbo Man
HONDA transmissions
And the 4 speed in the KA9's are bullet proof.....and work just great !
#86
Perhaps in North America, but not the world. I was just in The Azores (Portugal), and rented a Mazda 3 with a manual. Very nice except the reverse gear being top left, below 1st gear and down, and there is very few automatic cars there.
#87
Latent car nut
Received 2,008 Likes
#88
It's not full autonomous driving that's the short-term threat to the manual transmission, it's automatic braking systems. Unless something has changed in the past year or two, most major automakers have agreed in principle to make auto braking a standard feature by September 2022. Yes, auto braking can technically be used with a manual (BMW and Mazda), but the car will stall and need to be manually restarted. That in itself can be a hazard in a panic situation.
#89
Latent car nut
#90
Something like 99 or more percent of all modern clutch linkages are hydraulic, yes, no? If I was designing an automatic braking system for a car with a manual transmission, I'd simply put in an auto clutch disengagement system; the car emergency stops, you pump the clutch pedal once, away you go.
#91
Latent car nut
#92
#93
Unregistered Member
My good friend just had his 9-speed replaced in his 2015 TLX. He found out through the joke of Acura Corp. Torrance, CA that they are currently out of stock with new replacements and rebuilt replacement 9-speed transmissions. Luckily he bought the 120k AcuraCare Extended warranty and is covered. However, he's at 119,990 miles. So the replacement rebuilt transmission has no warranty, since Acura Care runs out in 10 miles. I am all in with meaningful improvements in engineering. But I am all out with Innovation Users Don't Need, e.g., ISDN from the late 80's.
Although I like the other improvements in the 2019 over my 2016, my point is I won't be doing any long term testing of these 10 speeds for Acura in the first few years. There simply is no history of reliability for the 10-speed. Without an extended Acura Care warranty a new owner is taking a HUGE gamble that the 10-speed is more reliable than the 9-speed.
#94
#95
My 2019 RDX ASPEC is in the shop getting a new 10 speed transmission right now. With only 30 miles on it there were already issues. Slamming in to gear at low speeds, revving up before finally engaging and just a general sloppy harsh shifting turd. The 10 speed has been having issues, there's plenty of people complaining about it. Sadly our first Acura, there won't be another. A week in the shop and Acura in CA told our shop to just replace it since they didn't know what else to do. I'd rather have a new car.
#96
#97
You'll Never Walk Alone
Mine has been awesome and getting better as the mileage goes up. Smooth and quick shifts, does exactly what I want at the right moment.
kingofbytes
06-14-2018 07:52 AM
Gunny Highway
07-13-2008 03:08 PM
MOBB
08-03-2007 07:40 PM
Zerostatic
06-04-2005 12:52 AM
AcuraTLFan
03-05-2003 03:31 PM
