tow with hybrid
Old 04-21-2018, 01:30 PM
getakey's Avatar
tow with hybrid
I bought the MDX Hybrid knowing that you should not tow with it. I have a ski boat that is in dry stack so they launch it for me. However, I'm moving to a house that is 5 minutes from a lake (not the place where I currently have boat in dry stack). They do not have dry stack, but have storage next to marina. Wondering:
1. does hybrid have space for hitch to be installed
2. risks of just towing the boat from storage to launch ramp - very short distance
Old 04-21-2018, 09:10 PM
p07r0457's Avatar
Yes the hybrid has the space and threaded holes for mounting the hitch.
According to Acura, the hybrid is NOT rated to tow. Neither the transmission nor electric drivetrain have tow ratings. Considering that you can put 7 people plus gear in an MDX, I’d think (hypothetically) it could pull a light boat for a short distance, as well... but if you choose to do that, it is entirely at your own risk. Acura doesn’t endorse it, and they won’t warranty anything that fails as a result of towing.
Old 04-21-2018, 09:16 PM
getakey's Avatar
I have a bike rack that fits in hitch. So if you put hitch on and only use for bike rack, they won't honor warranty?
Old 04-21-2018, 09:21 PM
p07r0457's Avatar
(I am neither a lawyer nor a representative of Honda/Acura)
The mere presence of a hitch does not necessarily mean you tow. Nor does a hitch cause a warranty to be void. However, Acura would be under no obligation to cover damage that was caused by towing.
So if your radio stops working, then no problem... warranty should take care of you. But if you’ve got the towing harness installed and your DCT is acting funny... you might have an uphill battle.
Old 04-21-2018, 09:23 PM
p07r0457's Avatar
Notice: a bike rack shouldn’t require tow harness — only hitch.
towing a boat (legally) requires working trailer lights, so you’d need the harness. I think that would be a red-flag to Acura. Again, they don’t “void” your entire warranty... they just won’t cover damage caused by the misuse/abuse.
Old 04-21-2018, 09:24 PM
getakey's Avatar
well I don't need a tow harness to back it down the launch ramp
Old 04-23-2018, 08:54 PM
mrgold35
mrgold35's Avatar
Received 1,508 Likes on 1,176 Posts
I've heard the issue is with the 7DCT being the weak point in towing. I've read DCT clutch packs can generate a lot of heat in low speed maneuvers under loads like slowly driving up a steep driveway or backing up/down a boat ramp. The sh-sh-awd would probably have 3500lbs of towing if it still had the 9AT. Very limited number of trucks and SUVs with DCT and towing capabilities compared to DCTs in "sporty" vehicles.
Old 04-23-2018, 09:05 PM
getakey's Avatar
well you sure put a damper on my plan
but backing down a ramp - most of the stress is on the Brakes
and pulling up the ramp - it would primarily be in the same gear
Old 04-23-2018, 09:30 PM
getakey's Avatar
well dang
Old 04-23-2018, 09:48 PM
mrgold35
mrgold35's Avatar
I think it is the characteristics of a DCT being a mix between an automatic and manual transmission (a 7MT with auto clutch). The DCT clutch plates are still engaged forward or reverse at low speeds. You might have to back down the ramp in neutral to fully disengage the clutch packs in a DCT? In my old manual days, I would sometimes slowly engage the clutch and gas to adjust my speed or full clutch and brake to stop when backing up at low speeds. I don't think I've ever backed up without my left foot on or just hanging over on the 3rd pedal. I think the 7DCT does the same thing at low speeds until you get into regular driving mode.
I really think if you don't exceed the max cabin weight of the sh-sh-awd, the 7DCT wouldn't know the difference between 400 lbs in the cabin/roof/hatch or 400lbs on a small trailer (depends on how heavy the ski boat).
Old 04-23-2018, 11:14 PM
getakey's Avatar
ski boat is fairly heavy
21 feet and V8 probably 3000 lbs
Old 04-24-2018, 08:30 AM
p07r0457's Avatar
It isn't an issue about being in-gear... It's the wet clutches. At low speeds, the clutches are partially engaged, but not fully engaged. That is necessary so that some slippage can occur so the engine doesn't stall. The clutches are in an oil bath, for cooling, but towing may be too much for the system to handle.
In a conventional transmission the torque converter would facilitate slippage during low-speed maneuvers. Torque converters also have a torque-multiplication effect at low speeds, which helps get you off the line when towing.
Old 04-24-2018, 08:31 AM
p07r0457's Avatar
It's your vehicle, so ultimately your decision. But if I had a MDX Sport Hybrid, that would be way too heavy for me to risk it.
Old 04-24-2018, 09:31 PM
getakey's Avatar
I'm thinking the same
Need an alternate plan - like a friend with a pickup
Barrett50.cl9
05-20-2017 01:49 PM
neil0311
01-05-2016 02:59 PM
gavriil
07-11-2005 06:05 AM
STL
01-06-2004 06:04 PM
jimcol711
04-15-2002 01:59 AM
Quick Reply: tow with hybrid
