2006 MDX w/65k Miles (Timing Belt)
Stay Out Of the Left Lane
Received 1,236 Likes
Your owner's manual is your friend.
The ’06 Owner’s and Service Manual says to follow the “Severe Conditions” schedule for Canadian owners. Both recommend a 105K mi/7yr. TB replacement interval in normal & severe conditions.
The Service Manual describes other extreme conditions and the Owner’s Manual goes on to recommend the 60K mi replacement under extreme temperature or towing.
So unless you are in Canada or operate in extreme conditions, from a mileage perspective you are fine. The long debated question is about the time interval and you will find lots of folks on both sides of the fence regarding this. As an example - https://acurazine.com/forums/3g-tl-2004-2008-93/2007-tl-type-s-timing-belt-913614/
9th Gear
So unless you are in Canada or operate in extreme conditions, from a mileage perspective you are fine. The long debated question is about the time interval and you will find lots of folks on both sides of the fence regarding this. As an example - https://acurazine.com/forums/showthread.php?t=913614
I had the old '03 belt replaced in 2011, despite only 62000 miles at the time; service advisor explained that the 7 year time lapse was just as pertinent as the 70K mileage threshold, as the belt begins to weaken and that's where the proverbial feces strikes the fan; it cost about $950, with a majority of cost alloted to the labor; I wouldn't have anyone but Acura perform this job
2G TLX-S
Pyannello, try posting in the 2G MDX sub-forum.
You'll certainly get more advices from the other 2G MDX owners.
asahrts
09-04-2015 05:55 PM
