1st Oil change - When?
When the computer says so. Usually a warning at 15%, then a red warning at 10%. I'd bring it in at 10%.
mrgold35
Warning starts a 15% and it shows every time you start the vehicle. Once you go past 0%, the car will start to count in negative mileage for being overdue. The reminder is easy to reset if it is annoying; but, it could effect the warranty if you forget to stick to the M.I.D. maintenance schedule and it directly causes a powertrain problem.
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
