Push Button Ign - Turn off the motor into ACC 1 Possible?
Old May 1, 2014 | 10:34 AM
808tesh's Avatar
Sorry I couldn't make the title explain my question better - I'm curious to know:
Can you turn the MDX off into ACC 1 from a running motor?
Or alternately, does a delayed power state exist when you turn the car off w/o opening a door (ie radio/windows still have power until a door opens)?
(ie, in a standard keyed car, when you turn the ignition back one step to turn off the motor, you end up in ACC 1, radio running, ac off, windows operable etc - or in some cars cases, delayed radio/window power until a door opens)
Is this possible, or anyone tried? I didn't come across it in the user manual
Thanks!
Old May 1, 2014 | 11:27 AM
RL06tech's Avatar
You push the button twice. In effect killing the engine and turning it to position one. Dont use the brake while doing it.
Old May 1, 2014 | 11:32 AM
808tesh's Avatar
I recall reading that and trying it - iirc, the radio dies in between presses? I'd really like to click the motor off with no break in radio/nav etc - the annoying part is having the system die and then take 30sec to be responsive again after it boots up...
Old May 1, 2014 | 03:16 PM
Kirill's Avatar
Originally Posted by 808tesh
Can you turn the MDX off into ACC 1 from a running motor?Is this possible, or anyone tried? I didn't come across it in the user manual
Thanks!
You need to press the On/Off button before putting shifter in P then it goes to Accessory mode instead of OFF.
p. 141 of manual
Old May 1, 2014 | 03:21 PM
808tesh's Avatar
p. 141 of manual
NICE find!
I've done that inadvertently (first auto trans I've owned) and thought I was about to mess something up - it's a counter-intuitive solution, so it must be OEM lol.
Thanks Kirill!
Old May 2, 2014 | 01:05 AM
SMMN's Avatar
You can also hold the transmission shifter button (in park) while also pressing the start button, without touching the brakes.
Old May 2, 2014 | 04:59 PM
Kirill's Avatar
Nice, just tried and it worked like a charm. And I like this way even better than the one I found in the manual.
How did you find this ? I don't remember seeing it in the manual.
Old May 2, 2014 | 11:09 PM
Kirill's Avatar
Tried the same (hold the transmission shifter button (in park) while also pressing the start button) but with the foot on the brake pedal with the same result - it went to Accessory mode instead of OFF. So, looks like the key is pressing the shifter button and touching or not the brakes doesn't matter.
Old May 3, 2014 | 01:31 AM
SMMN's Avatar
I think I read it on the RDX forum -my wife has a 14 RDX.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
PortlandRL
Sep 14, 2015 12:01 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
