Pre-delivery Inspection
Old Jul 13, 2014 | 08:24 AM
RL75252's Avatar
4th Gear
Question Pre-delivery Inspection
I will be picking up my MDX Tech later this week. When I do a walk through/inspection before signing paperwork - what should I be looking for other than the obvious physical damage? Thanks!
Old Jul 13, 2014 | 08:38 AM
aces2412's Avatar
Check all the seals where the doors, hood etc Look at the date the car was manufactured. You want later date if your buying a 14. Check the paint for scratches. Check the leather for tears etc. listen to the engine for any strange noises. Good luck!
Old Jul 13, 2014 | 09:02 AM
Willie3.5's Avatar
SixSpeedDreamin'
Whether the car is new/used have them put the car on a shop lift so you can investigate the under carriage of the vehicle. While you're inspecting the under carriage check for leaks, axles, etc...hope it goes goes well for you.
Old Jul 14, 2014 | 01:20 PM
upnorth85's Avatar
The dealer tried to fob off my inspection by not playing the DVD. Lucky I asked to demonstrate it. The cover was missing and the unit was defective. I noticed spots of body paint on my headlamp. I would strongly recommend max time doing inspection. Acura has dunces doing final inspection and dealers do a shoddy job. You are the only final inspector after final assembly.
SidhuSaaB
May 30, 2020 12:40 AM
prbori
Sep 27, 2015 01:37 AM
atsx1313
Sep 22, 2015 09:04 PM
peti1212
ILX
Sep 22, 2015 11:11 AM
Billu99tl
Sep 13, 2015 11:30 AM
