Need help for noise.
Old 04-30-2018, 01:06 PM
genny852's Avatar
Hello, I have a 16 mdx and 16 tlx as well. My 16 awd mdx started make some noise and need some help from you guys.
1. When I put gas slightly I hear like buzzing noise in front dash area and it goes away when off of gas. I found a post that has same issue with me but no solution there. The dealer replaced the cover and bolts but it still there. Buzzing/Vibration noise from firewall - Acura MDX Forum : Acura MDX SUV Forums
2. I have a rattle noise right after startup for a second especially when in cold. The dealer replaced the starter but It still there and now he says it is normal for that engine. What the. Also found a post that has exactly same noise but no solution as well. Buzzing/Vibration noise from firewall - Acura MDX Forum : Acura MDX SUV Forums
Please share if you have any idea. Thank you.
Old 04-30-2018, 01:22 PM
Received 16,263 Likes on 11,973 Posts
Hello!
while, I dont have an MDX, and don't know what the noise sounds like....from the threads you linked...I came to the conclusion that it's either something rubbing together to make a vibrating sound/frequency....and or could be electronics...
both suspects WILL NOT have a fix, unless you know exactly what/where it's rubbing...then you can employ a damping solution....like felt or rubber.
as for the electronics suspect, unless YOU know exactly what component it is; you can't fix the bad ground/power interference...if it's even that..
sac2006TL
14
04-09-2009 02:00 PM
CLSixspeed
02-27-2007 02:06 PM
pcaulfie
07-22-2004 11:18 PM
Quick Reply: Need help for noise.
