Heated Seats
Heated Seats
Why is it every time I get back in the car I have to turn on the heated seats again? I wish the heated seat setting would remain what it was previously. My old MDX had a physical rocker switch that of course could be left on.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
NelsonLee (02-10-2015)
Because that is the way Acura designed it to function.
Probably for the same reason the stereo blares when you restart, even if it was muted when you shut it off:
The people who designed it obviously never used it!
If they had, I would suspect it would work better.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Chris
Chris
No, it does not...describe your problem. My stereo works as advertised.
6G TLX-S
Heated seats (and heated rear windshield) are high current-drain devices, and shouldn't be left on continuously in order to prolong the battery life.
On my BMW, if you shut off the car for less than 15 minutes, they will come back on when you re-start. If longer than 15 minues, you will have to turn the heaters back on manually.
My previous vehicle remembered the mute setting on restart.
On the MDX, if I've hit the mute button on the steering wheel and then shut the car off, when I restart it the radio is un-muted and playing at whatever volume it was when I muted it.
If that is not normal, I'll have the dealer look at it.
Chris
I run the seat heat nearly constantly, winter or summer. Feels great on an aging and tweaked back.
Chris
As your your stereo issue...do you play music from CD player/HDD or do you plug something into USB?
The behavior I described is listening to XM, FM, or USB.
Another baffling quirk (compared to my Jetta) is when listening to an audio book on CD or local music on USB, the mute button does not pause playback. It keeps playing, then you lose your place in the book or can't pick up where you left off on the song you were listening to when you muted.
There is no 'pause' button on the screen either. It's like nobody put any thought into the actual usability of the system.
Chris
The MDX seats seem to be continuous, I do have to cycle them on/off at times because they get a bit too toasty! ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
There is no 'pause' button on the screen either. It's like nobody put any thought into the actual usability of the system.![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Chris
Chris
Maybe you need to try a 2015 model? Do you have a 2014? Mine works fine with music via iPhone thru USB.
JustPlaneChris (02-10-2015)
Mine is a 2015.
I have briefly listened to content from my old iPod, and it DOES have a pause button on the virtual screen, as there is on Pandora through my Android (bluetooth).
Apparently there's no consistency. <sigh>
Chris
Chris
Yeah, for me, i always have PLAY/PAUSE virtual button....
Argh, that is so irritating. I don't always want to listen to content from the iPod, because frankly I find it a PITA (I'm not an iOS guy).
Likewise, I don't always listen to Pandora because it eats up data (and is glitchy in the rural areas in which I often drive).
I guess I will just have to come to grips with the fact that the entire system is half-baked, and stop bitching. Moving on. Rant over.
- No pause ability for CD or USB playback
- No remembering 'mute' setting on restart
- No scrolling of XM song/artist info (it truncates, often with hilarious effect)
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
conelectric (02-23-2015)
2015 MDX SH-AWD TECH
Same bitch here. Our 2010 Honda Odyssey has the rocker switches. Seats will heat up automatically ( providing they were on the last time vehicle turned off.)
Interesting.
Chris
Chris
So, easy solution...instead of muting...turn it off.
Yep, I had determined that turning it off is the only way to "pause" an audio book on CD or USB. Not the end of the world, but certainly a puzzling design choice when so many other things can be done by feel with the safety and convenience of the steering wheel controls.
Chris
Chris
Chris
Chris
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
