Disable ANC
Old Nov 5, 2014 | 02:10 PM
john mai's Avatar
5th Gear
Angry Disable ANC
My MDX created a loud humming after installed an aftermarket speaker. Anyone know how to disable ANC on the 2015 MDX?
Thanks,
Old Nov 5, 2014 | 06:37 PM
dzionny_dzionassi's Avatar
Did you mean subwoofer? Disconnect mic in the back.
It should work, worked on my TL
Old Nov 6, 2014 | 12:55 PM
john mai's Avatar
5th Gear
We disconnected the mic in the back, still doesn't work. I think the only option is disable the ANC. I can't find the module
Old Nov 6, 2014 | 06:09 PM
Does your humming stops when you open the door?
Old Nov 7, 2014 | 12:00 PM
john mai's Avatar
5th Gear
Yes, It's stop when I open the door, or start the engine while the door is opened.
Old Nov 7, 2014 | 04:41 PM
007Acura's Avatar
Did you try the developer menu?
Old Nov 7, 2014 | 05:11 PM
john mai's Avatar
5th Gear
How to get into the developer menu. I have the Base MDX. Doesn't has the NAV button.
Old Nov 7, 2014 | 07:11 PM
007Acura's Avatar
You may not be able to get into it then. I would try different combinations with the menu and back button if you don't have nav.
like power+menu+back for 3 sec
etc...
Old Nov 7, 2014 | 10:31 PM
etc...
It will go to default when he will restart his car.. I assume there should be second mic somewhere...
Old Nov 10, 2014 | 11:50 AM
john mai's Avatar
5th Gear
power+back+menu or other button, didn't work. Do anyone able to disconnect the ANC module?
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
joflewbyu2
Oct 8, 2015 11:16 AM
kb1rl
Sep 30, 2015 10:17 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
kuzdu
Sep 10, 2015 08:42 PM
