Center console organization?
Old 02-04-2017, 09:10 PM
MCDavis's Avatar
What are y'all doing to organize the center console? Salex made a sweet divider for my truck, but they don't provide anything for the MDX. Has anyone found a divider to keep things from just loosely being all over the place?
Old 02-07-2017, 02:06 PM
MCDavis's Avatar
So I contacted the folks at Salex through their website. They don't have a direct fit for us, however with the dimensions I gave him, he was able to suggest a kit for a Toyota Highlander that is slightly longer and wider than our needs. Looks like I'll be trimming and sanding this weekend!!
Old 02-07-2017, 08:10 PM
sockr1's Avatar
Received 1,159 Likes on 909 Posts
Please report back with pics if you get it to work!
Old 02-07-2017, 08:22 PM
MCDavis's Avatar
Definitely going to make it work! It'll give me six divisions if it comes out like I've planned. I'll probably mock it up via cardboard and then transfer it to Salex's panels. They're about 1/8" thick so they're not super easy to cut, but I'll start slow and work away the material.
Old 02-08-2017, 06:43 PM
MCDavis's Avatar
Well, it's done, and I like it! I made the template out of cardboard as suggested. Basically I cut 4 pieces and did each wall individually. I then mated them up with the opposite wall and taped the two pieces together. I then transferred the templates over to the applicable pieces...one down the length and three side to side. I scored each piece with a very sharp utility knife and then continued to follow the scoring marks until the cut was deep enough to snap the piece without compromising the piece.
I think it turned out quite well.
Pics:
Attached Thumbnails Center console organization?-console-1.jpg   Center console organization?-console-2.jpg   Center console organization?-console-3.jpg   Center console organization?-console-4.jpg
sockr1 (02-09-2017)
Old 02-09-2017, 08:37 AM
MCDavis's Avatar
I'm happy to report no rattles! I was a little worried as the fit isn't as precise as if it were digitally measured, but it's darn close. I did slide a small sliver of automotive black carpet on the middle side-to-side divider as it was a touch loose. That sliver tightened it up well.
Next up is a magnet mount for my CCW.
Old 02-09-2017, 09:37 AM
Received 8,711 Likes on 6,718 Posts
Not bad..
MCDavis (02-09-2017)
Old 02-09-2017, 09:55 AM
sockr1's Avatar
looks good and glad you got it working! i don't know if i'll do this (my wife hates when i do anything to "her" car...so usually i don't tell her) but which exact kit did you get?
Old 02-09-2017, 10:04 AM
MCDavis's Avatar
Ha, I know how that goes. Luckily this one is my daily driver that we "share" to an extent.
Here's the Highlander kit they recommended based upon the dimensions I gave them. This kit is about 1" wider all around.
Amazon Amazon
sockr1 (02-09-2017)
Old 02-09-2017, 10:15 AM
TLbullet's Avatar
How much trimming was required? My wife would definately love this. and what tool did u use to trim?
Old 02-09-2017, 11:06 AM
MCDavis's Avatar
Trimmed between 3/4"-1" off each side of the pieces. A little more than that on the one central piece that runs front to back, as the console is about 12.5" at its longest point, and the piece is about 15" long.
I scored each piece with the utility knife around the template, then continued to follow the scoring marks with more pressure on the knife...making multiple passes. Eventually you work through enough material that you can break it at the scoring line. Kinda like how they score and cut glass.
I no longer have the need to keep the template around. I could put it in a FedEx envelope and send it wherever as long as the recipient paid for the shipping. My corporate rates through FedEx are pretty stellar.
Old 02-18-2017, 07:58 AM
Back in a Type S
ProvidenceLeaf's Avatar
Do you still have the template? I'll take it. Let me know how much you need from me to ship it. Thanks!
Old 02-18-2017, 07:02 PM
MCDavis's Avatar
Sure do. PM me your zip code and I'll see how much it'll be to drop it in USPS.
Old 02-19-2017, 08:34 PM
MCDavis's Avatar
The template is off to MA. Thanks Mark.
Old 02-22-2017, 03:01 PM
mdkxtreme's Avatar
Wow this is awesome stuff. With your center console being so big it would be really nice to have different slots.
MCDavis (02-22-2017)
Old 02-24-2017, 03:50 PM
MCDavis's Avatar
I have quite a bit of crap stored in there. Thoroughly enjoying the time it took in order to have some organization in there.
Old 06-24-2017, 12:39 PM
7th Gear
McRCN's Avatar
Now that it has been a few months, how has the organizer held up? Would you have done anything differently?
Old 06-25-2017, 08:09 PM
MCDavis's Avatar
Makes no noise. Holds everything I could need it to hold. Not sure I would have done much differently other than taking more time to make it perfect. It's close as it is!
