2020 Acura MDX Technical Service Bulletins
Forum Contributor
Received 1,391 Likes
2020 Acura MDX Technical Service Bulletins:
TSB 19-036 - 2020 MDX: TQI and New Model Service Information
Applies To: 2020 MDX - 2WD - Base, With Technology Package, With Technology Package and Entertainment Package, With Advance Package, With Advance Package and Entertainment Package
2020 MDX - SH-AWD - Base, With Technology Package, With Technology Package and Entertainment Package, With A-Spec Package, With Advance Package, With Advance Package and Entertainment Package, PMC Edition
http://www.urvi.net/forumfiles/SB/B19-036.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-036.PDF
TSB 19-037 - 2020 MDX: TQI of the Navigation System
Applies To: 2020 MDX - ALL
http://www.urvi.net/forumfiles/SB/B19-037.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-037.PDF
TSB 19-038 - 2020 MDX Sport Hybrid: TQI Information
Applies To: 2020 MDX Sport Hybrid - With Technology Package, With Advance Package
http://www.urvi.net/forumfiles/SB/B19-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-038.PDF
TSB 19-039 - 2020 MDX Sport Hybrid: TQI of the Navigation System
Applies To: 2020 MDX Sport Hybrid - ALL
http://www.urvi.net/forumfiles/SB/B19-039.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-039.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-20 MDX
2017-20 MDX Sport Hybrid
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-013 - Navigation Display Distorts After 1 or More Hours of Driving
Applies To: 2018-20 MDX - Tech Advance, Hybrid Tech, Hybrid Advance, A-Spec - ALL
http://www.urvi.net/forumfiles/SB/B20-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-013.PDF
http://techinfo.honda.com/rjanisis/p...enu/B14162.PDF (Link works, but is wrong)
TSB 20-015 - 9-Speed A/T Hard Upshift with Steady Acceleration
Applies To: 2016-19 MDX - ALL - ALL
2020 MDX - AWD - From VIN 5J8YD4...LL000001 thru 5J8YD4...LL011456
2020 MDX - 2WD - From VIN 5J8YD3...LL000001 thru 5J8YD3...LL003798
http://www.urvi.net/forumfiles/SB/B20-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-015.PDF
TSB 20-019 - Driver's and Front Passenger's Seat-Back Clicks or Pops
Applies To: 2019-2020 MDX - ALL - ALL
2019-2020 MDX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B20-019.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-019.PDF
TSB 20-022 - Service Manual Update: Second-Row Seat Frame Replacement
Applies To: 2014-20 MDX
http://www.urvi.net/forumfiles/SB/B20-022.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-022.PDF
TSB 20-039 - Emissions Recall: 2017-20 MDX Sport Hybrid Odd Gear Monitor Software Update
Applies To: 2017-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B20-039.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-039.PDF
TSB 21-013 - Safety Recall: 2019-20 MDX and MDX Sport Hybrid Fuel Pump Motor
Applies To: 2019-20 MDX - ALL - Check the iN VIN status for eligibility
2019-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B21-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-013.PDF
TSB 21-016 - Safety Recall: Multi-Model Fuel Pump Motor
Applies To: 2019-20 MDX - 2WD - ALL - Check the iN VIN status for eligibility
2019-20 MDX - SH-AWD - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B21-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-016.PDF
TSB 23-001 - Product Update: 2016-23 MDX PGM-FI Idle Stop Software Update
Applies To: 2016-20 MDX - All (except Hybrid) - Check the iN VIN status for eligibility
2022-23 MDX - All (except Hybrid & Type S) - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-001.PDF
TSB 23-002 - Warranty Extension: Engine Does Not Auto Restart After Entering Auto Idle Stop
Applies To: 2016-20 MDX (with 9A/T) - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-002.PDF
TSB 23-009 - Engine Does Not Crank
Applies To: 2016-20 MDX - ALL (except Hybrid) - ALL
http://www.urvi.net/forumfiles/SB/B23-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-009.PDF
TSB 23-023 - Safety Recall: 2020 MDX Brake Master Cylinder Mounting Inspection
Applies To: 2020 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-023.PDF
TSB 23-024 - 2019-20 MDX A/C Compressor Shaft Seal Leak
Applies To: 2019-20 MDX - A-SPEC, ADV, BASE, TECH - ALL
http://www.urvi.net/forumfiles/SB/B23-024.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-024.PDF
TSB 23-035 - MIL Comes on with DTC P0441
Applies To: 2018-20 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B23-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-035.PDF
TSB 23-036 - Safety Recall: 2015-20 Multi-Model Connecting Rod Bearing Stop Sale
Applies To: 2016-20 MDX - ALL (except Hybrid) - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-036.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-036.PDF
TSB 24-001 - Safety Recall: 2016–20 MDX Connecting Rod Bearing
Applies To: 2016-20 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-001.PDF
TSB 24-006 - Safety Recall: 2014–20 MDX and 2018–20 MDX Sport Hybrid Fuel Pump Motor
Applies To: 2014-20 MDX - ALL - Check the iN VIN status for eligibility
2018-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-006.PDF
http://techinfo.honda.com/rjanisis/p...B24-006 v2.PDF (Link works, but is wrong) Version 2
TSB 24-014 - Safety Recall: 2020 MDX Seat Weight Sensor (DTC U3000-49)
http://www.urvi.net/forumfiles/SB/B24-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-014.PDF
TSB 24-021 - Safety Recall: 2020–22 Multi-Model Seat Weight Sensor Stop Sale
http://www.urvi.net/forumfiles/SB/B24-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-021.PDF
TSB 24-023 - Safety Recall: 2020–22 Multi-Model Seat Weight Sensor Campaign Notice
Replaces the campaign notice dated February 27th.
NOTE: This notice is to keep all dealers with the most up-to-date information for this safety recall. Dealers will be notified when this notice is revised.
http://www.urvi.net/forumfiles/SB/B24-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-023.PDF
grodri02
3G MDX (2014-2020)
07-13-2017 01:51 PM
