2017 Bolt Pattern
6G TLX-S
The 2017 MDX needs this wider 5x120 bolt pattern, because it starts using the big-ass 20" wheels as standard equipment.
Can't edit previous but looking at the part diagrams, the only things that changed are the hub assembly and the bolts, so if one ever wanted to, you COULD change to 5x120 pretty easily on the 2014-2016s. Not that most people ever would, but 5x120 wheel options tend to be much nicer.
Former Sponsor
mrgold35
Does the 14-16 and +17 use ball or conical lug nuts?
I have RonJon rims on my 08 RDX (+6yrs) and 11 MDX(+2yrs) and they look way better than any factory rims. No messing around with hubcentric rings, zero issues with TPMS x-fer, final wheel finish limited to your imagination, and plenty of styles to pick from. The only two minor issues I had to do was:
- need to keep a set of the OEM ball lugs in the vehicles for the OEM spare since the RonJon rims use conical lugs.
- purchased a second set of wheel locks because the RonJon spline wheel locks with socket key are becoming more common. I have Gorilla wheel locks along with the RonJon locks.
Aren't all OEM wheels ball nut
6G TLX-S
Ron good to see you back on Acurazine! What 5x120 20 inch wheel options do you have? I'm thinking of putting snow tires on my stocks and getting a set of summer wheels and tires.
Former Sponsor
Sup, another 2001 OG!
Just running with the best sellers, the 18" & 19" Legacy-MC7 and the 18" Rev-GT5 wheels and I still have some 20" Inspyre type II in stock.. Also started production back up on the 4G TL grille and bodykits. Basically pretty busy with these products while trimming the fat so to speak and discontinuing some wheels like the Harrow, Stryfe and Legacy type II. Still some dwindling inventory of those wheels though. Once I get everything produced, we will see if there is any interest in a new product or wheel. Anything in mind that I could should briefed on?
6G TLX-S
4G TL grille and bodykits -
Hello lo how can I get. Contact w you abut CNC machine??
Much easier to convert the wheel to a 5 x 120, such an easy change without disassembling the vehicle, we actually do it with a CNC machine and press in new steel insert seats. Or you could just get some RJ wheels that are hubcentirc and built to fit perfectly. 18", 19" and 20" that are 20% lighter than factory.
Please can u give me your info of this company to get this job done I got 2017 wheels that need CNC machine and new steel inserts
