2014 Acura MDX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2014 Acura MDX Technical Service Bulletins:
TSB 13-023 - 2014 MDX: TQI Information
Applies To: 2014 MDX - ALL
http://www.urvi.net/forumfiles/SB/B13-023.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-023.PDF
TSB 13-022 - 2014 MDX: TQI of the Navigation System
Applies To: 2014 MDX With Navigation - ALL
http://www.urvi.net/forumfiles/SB/B13-022.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-022.PDF
TSB 13-028 - Safety Recall: Accessory Trailer Harness Wires Mislabeled
Applies To: 2014 MDX - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B13-028.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-028.PDF
TSB 13-039 - Ticking from the Dashboard or Front Damper
Applies To: 2014-15 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B13-039.PDF
http://techinfo.honda.com/rjanisis/p...nu/B13-039.PDF
TSB 13-042 - Safety Recall: Propeller Shaft Bolts May Be Loose or Missing
Applies To: 2014 MDX with SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B13-042.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-042.PDF
TSB 14-003 - Noise From the Front of the Vehicle
Applies To: 2014 MDX - 2WD - From VIN 5FRYD3H..EB000001 - 5FRYD3H..EB014299
2014 MDX - SH-AWD - From VIN 5FRYD4H..EB000001 - 5FRYD4H..EB028341
http://www.urvi.net/forumfiles/SB/B14-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-003.PDF
TSB 14-014 - Vehicles with Navigation: Audio Turns Off After Using HFL, No Sound/Static in Rear Headphones, and Other Listed Issues
This bulletin is replaced by S/B 15-001, Vehicles with Navigation: Audio Turns Off After Using HFL, No Sound/Static in Rear Headphones, and Other Listed Issues
http://www.urvi.net/forumfiles/SB/B14-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-014.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2014-18 MDX - ALL - ALL
2019 MDX - 2WD - From VIN 5J8YD3...KL000001 thru 5J8YD3...KL005096
2019 MDX - AWD - From VIN 5J8YD4...KL000001 thru 5J8YD4...KL011104
2019 MDX Sport Hybrid - From VIN 5J8YD7...KL000001 thru 5J8YD7...KL000483
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 14-026 - MID Reads "12 Volt Battery Charging System Problem"
Applies To: 2014 MDX - 2WD - From VIN 5FRYD3H..EB000001 thru 5FRYD3H..EB016054
2014 MDX - SH-AWD - From VIN 5FRYD4H..EB000001 thru 5FRYD3H..EB032792
http://www.urvi.net/forumfiles/SB/B14-026.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-026.PDF
TSB 14-031 - Steering Column Screeches When Moving
MDX was removed from this bulletin. Refer to service bulletin 18-033, 2014-16 MDX: Steering Column Screeches When Moving.
TSB 14-033 - Oil Filter Is Hard to Remove
Applies To: 2014 MDX - 2WD - From VIN 5FRYD3...EB000001 thru 5FRYD3...EB017889
2014 MDX - SH-AWD - From VIN 5FRYD4...EB000001 thru 5FRYD4...EB039646
http://www.urvi.net/forumfiles/SB/B14-033.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-033.PDF
TSB 14-035 - Second Row Seats Stained by Acura Genuine Accessory Second Row Seat Covers
http://www.urvi.net/forumfiles/SB/B14-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-035.PDF
TSB 14-038 - Safety Recall: Front Seatbelts Will Not Extend or Retract Properly in Extremely Cold Weather
Applies To: 2014-15 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-038.PDF
TSB 14-045 - Power Steering Buzz or Grunt After Shifting From Reverse
2015 MDX - 2WD - From VIN 5FRYD3H4.FB000001 thru 5FRYD3H4.FB006937 and 5FRYD3H8.FB000001 thru 5FRYD3H8.FB007398
2015 MDX - SH-AWD - From VIN 5FRYD4H4.FB000001 thru 5FRYD4H4.FB016167 and 5FRYD4H8.FB000001 thru 5FRYD4H8.FB016387
http://www.urvi.net/forumfiles/SB/B14-045.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-045.PDF
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
http://www.urvi.net/forumfiles/SB/B14-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF
TSB 15-001 - Vehicles with Navigation: Audio Turns Off After Using HFL, No Sound/Static in Rear Headphones, and Other Listed Issues
Replaces S/B 14-014, Vehicles with Navigation: Audio Turns Off After Using HFL, No Sound/Static in Rear Headphones, and Other Listed Issues
Applies To: 2014 MDX - ALL with navigation - ALL
http://www.urvi.net/forumfiles/SB/B15-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-001.PDF
TSB 15-007 - MIL Comes On With DTC P0134 /P0154
http://www.urvi.net/forumfiles/SB/B15-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-007.PDF
TSB 15-009 - Rattle from the Second Row Passenger Seat on Rough Roads
Applies To: 2014 MDX - ALL with 2WD - From VIN 5FRYD3H..EB000001 thru 5FRYD3H..EB009288
2014 MDX - ALL with SH-AWD - From VIN 5FRYD4H..EB000001 thru 5FRYD4H..EB019090
http://www.urvi.net/forumfiles/SB/B15-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-009.PDF
TSB 15-017 - AcuraLink System Status Indicator Is Red and DTC B1403 Will Not Clear
2015 MDX - 2WD with navigation - From VIN 5FRYD3...FB000001 thru 5FRYD3...FB007880
2015 MDX - SH-AWD with navigation - From VIN 5FRYD4...FB000001 thru 5FRYD4...FB018838
http://www.urvi.net/forumfiles/SB/B15-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-017.PDF
TSB 15-023 - HomeLink System Has Weak or Limited Range
Applies To: 2014–16 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-023.PDF
TSB 15-029 - Safety Recall: MDX CMBS Error
Applies To: 2014–15 MDX - Advance and Advance SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-029.PDF
TSB 15-036 - HVAC Display Flashes or Flickers
Applies To: 2014–15 MDX - ALL with navigation - ALL
http://www.urvi.net/forumfiles/SB/B15-036.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-036.PDF
TSB 15-037 - Safety Recall: A/C Compressor Clutch Bolt
Applies To: 2014–15 MDX - ALL with 2WD - Check the iN VIN status for eligibility
2014–15 - MDX - ALL with SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-037.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-037.PDF
TSB 15-046 - Security System Sounds or May Not Set
Applies To: 2014–15 MDX - ALL - ALL
2016 MDX - ALL 2WD - From VIN 5FRYD3H..GB000001 to 5FRYD3H..GB007326
2016 MDX - ALL SH-AWD - From VIN 5FRYD4H..GB000001 to 5FRYD4H..GB029373
http://www.urvi.net/forumfiles/SB/B15-046.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-046.PDF
TSB 15-053 - MIL Comes On with DTC P0430
This bulletin is replaced by S/B 17-034, MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
http://www.urvi.net/forumfiles/SB/B15-053.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-053.PDF
TSB 16-001 - Remote Engine Start System Poor Range Performance
http://www.urvi.net/forumfiles/SB/B16-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-001.PDF
TSB 16-008 - High Pressure Fuel Pump Chirps
Applies To: 2014-17 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-008.PDF
TSB 16-035 - Rattle or Clunk from the Rear Suspension
Applies To: 2014-16 MDX - ALL with 2WD - ALL
2014-16 MDX - ALL with 4WD - ALL
http://www.urvi.net/forumfiles/SB/B16-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-035.PDF
TSB 16-042 - Squeak and/or Pop from the Front Suspension While Turning
2014-16 MDX - ALL with SH-AWD - ALL
http://www.urvi.net/forumfiles/SB/B16-042.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-042.PDF
TSB 16-056 - Power Tailgate Does Not Work
2016 MDX - 2WD - From VIN 5FRYD3...GB000001 thru 5FRYD3...GB021145
2016 MDX - SH-AWD - From VIN 5FRYD4...GB000001 thru 5FRYD4...GB061341
http://www.urvi.net/forumfiles/SB/B16-056.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-056.PDF
TSB 16-062 - 2012–15 MDX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2012 MDX - ALL - From VIN 2HNYD2H...CH513517 thru 2HNYD2H...CH550713
2013 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-062.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-062.PDF
TSB 16-063 - 2012–15 MDX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B16-063.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-063.PDF
TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power
Applies To: 2014–15 MDX - Tech/Adv - ALL
2016 MDX - 2WD Tech/Adv - From VIN 5FRYD3...GB000001 thru 5FRYD3...GB016493
2016 MDX - SH-AWD Tech/Adv - From VIN 5FRYD4...GB000001 thru 5FRYD4...GB049096
http://www.urvi.net/forumfiles/SB/B17-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF
TSB 17-008 - Buttons Sticking on Center Switch Panel/Interface Dial (Day/Night, SETTINGS, NAV, AUDIO, or others)
Applies To: 2014–17 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-008.PDF
TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
Applies To: 2014-16 MDX (except Sport Hybrid) - ALL - ALL
2017 MDX (except Sport Hybrid) - 2WD - From VIN 5FRYD3...HB000001 - 5FRYD3...HB014264 and 5J8YD3...HL000001 - 5J8YD3...HL000229
2017 MDX (except Sport Hybrid) - SH-AWD - From VIN 5FRYD4...HB000001 - 5FRYD4...HB040999 and 5J8YD4...HL000001 - 5J8YD4...HL000507
http://www.urvi.net/forumfiles/SB/B17-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-034.PDF
TSB 18-014 - Clicking from the Power Seat While Using the Height or Tilt Adjustment
2017-18 MDX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-014.PDF
TSB 18-033 - 2014-16 MDX: Steering Column Screeches When Moving
2016 MDX - 2WD - From VIN 5FRYD3H..GB000001 thru 5FRYD3H..GB020812
2016 MDX - SH-AWD - From VIN 5FRYD4H..GB000001 thru 5FRYD4H..GB060678
http://www.urvi.net/forumfiles/SB/B18-033.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-033.PDF
TSB 18-035 - ATF Leak from Transmission Case Bolt
Applies To: 2014 MDX - All with SH-AWD - From VIN 5FRYD4H..EB030353 thru 5FRYD4H..EB041381
http://www.urvi.net/forumfiles/SB/B18-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-035.PDF
TSB 19-017 - Buzzing or Whining When Adjusting Front Seat Forward and Backward
Applies To: 2014-19 MDX - ALL - ALL
2017-19 MDX Sport Hybrid - ALL - ALL
2015-19 TLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-017.PDF
TSB 19-019 - Safety Recall: 2014-19 MDX Inner Lights
Applies To: 2014-19 MDX - ALL - Check the iN VIN status for eligibility
2017-19 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-019.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-019.PDF
TSB 19-027 - Service Manual Update: 2014-19 MDX and 2017-19 MDX Sport Hybrid Inner Taillight Sub Harness
http://www.urvi.net/forumfiles/SB/B19-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-027.PDF
TSB 19-029 - Warranty Extension: White Diamond Pearl Paint
Applies To: 2014-16 MDX - All vehicles painted White Diamond Pearl NH-603 - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-029.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-20 MDX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-022 - Service Manual Update: Second-Row Seat Frame Replacement
Applies To: 2014-20 MDX
2017-20 MDX Sport Hybrid
http://www.urvi.net/forumfiles/SB/B20-022.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-022.PDF
TSB 24-006 - Safety Recall: 2014–20 MDX and 2018–20 MDX Sport Hybrid Fuel Pump Motor
Applies To: 2014-20 MDX - ALL - Check the iN VIN status for eligibility
2018-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-006.PDF
http://techinfo.honda.com/rjanisis/p...B24-006 v2.PDF (Link works, but is wrong) Version 2
