Will these fit?
Will these fit?
Looking at a set of xxr 527's in 18x9.75, 20mm offset with 235/40/18 tires. Currently not lowered, but may lower with h&r's or tein's. Will I have any issues? Which type of lug nuts do I need?
Thanks!
Thanks!
SeeYou2Crew #2
the "correct" tire size should be 235/35 (235/40 will have a bigger change compared to your stock diameter, messing up your speedo)
you will need aftermarket lug nuts, (most should be tapered ends)
I have 10.5s all around am have no problems...so if i can do it...you are all set
+40 all around
im 9.5 +12 all around that .25 cant be THAT much of a difference im lowered with rolled and pulled fenders, stock camber i have plenty of clearance in the back and the fronts are barely rubbing.
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
