TSX Sway bar differences betwwen these two?
Hey guys just wondering are these the same sway bars? same company?
http://www.heeltoeauto.com/progress-...roductid=64803
http://store.excelerateperformance.c.../i-309850.aspx
i'm confused because it's a big price difference
I did a little research to confirm that there are two bars as listed in the links. There may be more to it that just the size though; a call to either of the vendors should uncover any discrepancies or special circumstances. If you do replace the sway bar, I'd suggest replacing the end links too. Moog offers replacements that are much beefier and have grease fittings installed (and they're cheap; about $20 a piece from Rockauto for instance).
Speedy164 (07-17-2013)
Graphite Ghost
according to progress site there is ONE CU2 bar at 22MM.
http://www.progressauto.com/products...l=TSX&x=20&y=4
yup just saw them on your build thread damn those are nice and beefy compared to the stock ones... i guess i will be going for these since i don't know about the excelerate performance price difference and 3mm more, you have the sport wagon and happy with the the bar as it is so i should definitely love it as well. Next up fog Projectors!!
Former Sponsor
This is the only Progress RSB actually in production for the 2G TSX.
http://store.excelerateperformance.c.../i-248908.aspx
This bar I believe was a track inspired bar. We could probably special order it but it isn't a regular production item.
robpp (07-18-2013)
TSX x2
![](https://distilleryimage6.ak.instagram.com/66038c4cdeaf11e28bc322000a9d0dcb_7.jpg)
![](https://distilleryimage5.ak.instagram.com/fd89bb147ca211e2ac8a22000a9e2947_7.jpg)
I love my Progress 25mm RSB setup!!! Not sure if its discontinued, took over 1 month for me to receive this... Improved turn in response compared to the 22mm. Little bit of oversteer, added 10mm spacers on the rear, readjusted rear camber, and slightly soften damper to compensate the added rear response. Feeling: "Go Kart" Very stiff and solid bar w/ reinforcement brackets and adjustable endlinks, why pricing is a little bit more... Fabrication and drilling to chassis is required since this was designed for track use (Mid-Ohio Specifications). (Warranty VOID
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Current Suspension Setup 7/13:
XLR8 ISC-N1 Coilovers 32way Suspension Street/Sport 12K/8K
Eibach/SPC Adjustable Rear Camber Control Arms
Megan Racing Adjustable Rear Toe Control Arms MR-6724
Megan Racing Adjustable Rear Lateral Traction Arms MR-6756
Progress Anti Roll Bar 25MM Rear Sway Bar Mid-Ohio Spec
Progress Rear Sway Bar Reinforcement Kit Mid-Ohio Spec
Progress Anti Roll Bar Spherical Rear Sway Bar Endlink Kit
Energy Suspension 25MM (1") Greaseable Sway Bar Bushings
Whiteline Performance Suspension 25-27MM (1") Rear Sway Bar Alloy Lateral Lock Kit
UltraRacing Front Tower Strut Brace (TW2-547)
UltraRacing Front Member Brace (LA2-548)
UltraRacing Mid Lower Bar (LA2-623)
UltraRacing Rear Lower Bar (RL2-775)
UltraRacing Rear Member Brace (RL2-776)
UltraRacing Rear Side Bars - Set of 2 (RLS4-777p)
holy frog (02-08-2016)
I love my Progress 25mm RSB setup!!! Improved turn in response compared to the 22mm. Very stiff and solid bar w/ reinforcement brackets and adjustable endlinks... Fabrication and drilling to chassis required. (Warranty VOID
Suspension:
marcelft
07-10-2018 06:17 PM
Puma Jim
20
10-20-2016 11:59 AM
joflewbyu2
10-08-2015 11:16 AM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
