Tire size question
Tire size question
Do you guys think 235/55/18 would be to big of a tire to run for the winter I have a buddy with Rdx wheels and tires for sale really cheap and I wanna know if you guys think the tire size would be an issue?
Diameter difference of 8%
speedometer will be 8% slower
additionally, you can go to http://www.1010tires.com/tiresizecalculator.asp
^he's your buddy right?
swap rims to test fit.
being wide isnt the issue.
its the profile height thats the issue, again making your speedo off by 8%
and any taller tire than stock will look funny....
yes that is the specs of our stock tires. and 8% is a lotttt and you're screwing with your odometer which can result in voiding of the warranty (ceb's power has infused me) so if you feel like screwing with your warranty, go for it. i would not use those tires though.
I gave you the website to the calculator....
really, all you have to do is punch in numbers...and it does the math for you.
You want to stay as close as factory rolling diameter as possible.
with the new proposed tire size, there is a diameter difference of 6%.
to me, thats still too much.
your speedo will be off.
a 245/40/19 WOULD BE BETTER.
But also depends on wheel selection and its specs.
All you need to research and learn about fitment:
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/wheel-tire-fitment-resources-821398/
nuldabz
Sep 3, 2015 05:49 PM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:05 PM
