Rims/Wheels specs
Rims/Wheels specs
Hey guys, I'm not sure if anyone's already made a thread like this yet or if there's one similar to this butttttt.... I just want to make a thread where people can post up both their tyre and rim specs so noobs like me can take in some knowledge hopefully and save us all some hassle. It wouldn't hurt right?
Maybe in a format?
Rims:
Size and offset:
Brand of tyres (if it matters):
Size?:
Suspension:
Did you need to roll guards?
Spacers?
If anyone can fix it up or suggest anything, that'd be great.
Thanks guys!
Edit: Maybe a picture too if you'd like.
Maybe in a format?
Rims:
Size and offset:
Size?:
Suspension:
Spacers?
Thanks guys!
You see me, I CU2
Great idea!
Rims: OEM
Heavy as FUCK
Size and offset: 17 x 7.5 +55(?)
Brand of tires: Michelin
Suspension: Stock, Made in Japan! MAD JDM TYTE YO!
Did you need to roll guards: No, but I could use some flaring and pulling in the future for the next set![Too Cool](https://acurazine.com/forums/images/smilies/toocool.gif)
Spacers: Could use some
All jokes aside, this would be beneficial for all members. Unfortunately the noobs won't use the SEARCH BAR and proly make redundant threads but I digress.
Rims: OEM
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Unregistered Member
On the '09 n '10's I've seen/read about people who were dropped and had 20's with no rubbing.
SeeYou2Crew #2
i THOUGHT we had a thread similar, but i could be reading teh 1st gen section ahah
nonetheless, it will be some good info
however...i have nothing to contribute untill my wheels are mounted and i get a nice drop :p
Rims: Ron Jon Legend in Liquid Graphite
Size and offset: 19x8 +32
Brand of tyres: Bridgestone Pole Position RE950
Tire Size: 245/35R19
Suspension: Stock
Roll fenders: Nope
Spacers: Nope
That said I don't want 245/35R19 again. I will either switch to 225/40R19 or 245/40R19. I can't decide if I want a little bit of a stretched look yet or not. Either way I am going with the Continental Extreme Contact DWS.
I plan to go Tein Basic Coilover in the very far away future.
Picture in Avatar and you can check my garage if you want to see it bigger. I need to add better picks but thats the only one I got for now. I just put the wheels on this week.
Suspension: Stock
Roll fenders: Nope
Spacers: Nope
This is a great idea, these threads always end up helping many people. I would add a few more points though.
Example:
1.Brand of Rim - Enkei
2.Rim size (diameter and width) - 17" x 8"
3.Offset - 45mm
4.Brand of tire - Pirelli PZero Nero M+S
5.Tire size - 235/45/17
6.Drop Type and Amount - H&R drop
7.Do they rub - No rubbing
8. Camber specs
9. Spacers - ie. Y/N, how wide?
10. Fender modifications
11. Weight (if possible) - XX lbs
12. Picture
I first got the idea from someone who showed me the thread the TL guys have:
https://acurazine.com/forums/2g-tl-tires-wheels-suspension-100/new-wheel-tire-specs-thread-pics-602066/
It then worked decently well for the 5th Gen Maximas too:
http://forums.maxima.org/5th-generat...cs-thread.html
Example:
3.Offset - 45mm
8. Camber specs
12. Picture
Example:
3.Offset - 45mm
8. Camber specs
12. Picture
https://acurazine.com/forums/showthread.php?t=602066
Example:
3.Offset - 45mm
8. Camber specs
12. Picture
Does anyone know the weight and offset of the stock wheels. Being that it is an acura/honda product, I doubt it's anything but +45 offset, but I really want to know the wheel weight.
Rims: Stock
Size and offset:Stock
Brand of tyres (if it matters): Yokohama
Size?: 225/45/17
Suspension: Tein Basics, Progress RSB, Ultra Racing chassis braces, SPC full control arm suite in rear suspension
Did you need to roll guards?: N/A
Spacers?: N/A
I want some enkei wheels, either in 17 or 18, but at a minimum x8 preferably 8.5 and looking at the RPF01 or Raijin.
Size?: 225/45/17
Spacers?: N/A
Pretty sure it is +55 offset, but someone correct me if I'm wrong. Stock 17 rim is 17x7.5 and weight is approx 24 lbs, without the tire.
ed_423 (11-30-2011)
Let's try to re-kickstart this thread again... wheel specs please, there are many of you posting your set ups in the Gallery, so maybe you can post some specs here. Thanks.
Example:
3.Offset - 45mm
8. Camber specs
12. Picture
Example:
3.Offset - 45mm
8. Camber specs
12. Picture
emailnatec
29
09-28-2018 04:27 PM
