Question on poke
Im running 19x9 +45 all around and Im not even close to poke..im just flush. Weird.
Well the wheels are 19x9 ET35 stamped on the back but's funny when i meassure them form the "outside" lip to lip they are 10" on the "inside" they are 9"......maybe thats why i get 10mm almost 1/2" outside the fender
Any idea on tire size to make it look good - some stretch maybe?
No drop yet but thinking either eibach or maybe megan coilovers....
eibach - confortable ride but maybe rubbing
coilovers - exact drop but sacrifice ride
Get coilovers if you're getting into stance and dialing in the perfect drop/look. Actually, springs on stock shocks will generally be more harsh than coilovers. I'm pretty low on Tein SS and I think the car drives nice and smooth.
Also, based on that picture...when you put the car down on that rim, you will get some negative camber and it will sit perfectly. Won't be bad. Maybe need a fender roll but it'll be worth it.
225 or 235...
Thanks to all, ill be ordering the coilovers and ill try 235
They are MRR's "exe replicas" painted flat black
im pretty sure you will poke out less than your pics once you actually get tires on and have contact with the ground
WTH happened to my garage
FWIW, when you measure a wheel width, it's the inside measurement where the bead of the tire seats that is the width we use when describing a wheel, not the outside measurement.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
navtool.com
09-25-2015 05:15 PM
