offset question
Old Aug 10, 2012 | 09:33 PM
SteVe-inTSX's Avatar
offset question
interested in throwing some 19 inch vossen CV 3's on my 2010 pwp.
only problem is the lowest offset they come in is 32mm
is this going to be a problem
i know 35mm is a popular offset and anything higher than 35 will fit but is 32mm going to stick out to far?
Old Aug 10, 2012 | 11:00 PM
ed_423's Avatar
SeeYou2Crew #2
what's the width?
my rear is +30 and its 9.5" wide.
front is +39. im sure i can push +30 up front.
Old Aug 11, 2012 | 02:35 PM
19x8.5 all around +32
Old Aug 11, 2012 | 09:48 PM
chaqui74's Avatar
Your good to go.... So your not going with the staggerd look?
Old Aug 12, 2012 | 12:35 AM
Honestly i would love too
but my dads not into the idea of not being able to rotate my tires so that shot down my hopes of a staggered setup
I love cv3's but 20's were always a bit out of my price range so now that 19's are available i want them.
then i plan on dropping my car with some tein h-tech springs
Old Aug 12, 2012 | 11:31 AM
and one more thing..
is a 73.1mm hub going to be a problem..i never fully understood what that meant or what it has to be
Old Aug 12, 2012 | 12:34 PM
ed_423's Avatar
SeeYou2Crew #2
just buy some hubrings that converts 73.1 to 64.3 (?) don't remember what our cars are. the are only like 10 bucks for 4, so you shouldn't have too many things to worry about
Old Aug 13, 2012 | 09:53 AM
Slo AP2's Avatar
With that size your golden. I'm running 8.5's +30 in front and 9.5's +25 in rears.
Old Aug 13, 2012 | 10:22 AM
helmsrj's Avatar
08 Type-S KBP
I do concur my good sir. Vossen's are hot.
Old Sep 14, 2012 | 04:55 AM
6MTSX's Avatar
Coming from a car which had the entire lug attach from the outside, rather than the built in studs which the tsx has I am a bit confused regarding offset and stud length. It is my understanding that if one uses a type I spacer (hubcentric) this reduces the offset by pushing the entire rim and hub toward the outside. eg. stock +55et rims with 10mm spacers= 45et. would reduce my thread area by 10mm. Now, if I were to purchase new rims with an offset of +45, would the length of the stud be affected in anyway? I was originally considering spacers, but am just thinking of doing things right and getting a wheelset that is more aggressive. Thanks in advance.
Old Sep 15, 2012 | 02:46 PM
VortexBlueTSX's Avatar
do you think 19x10 +38 will be a problem?
Old Sep 15, 2012 | 10:04 PM
SlickxAc's Avatar
im not sure if that will fit the front, but im pretty sure that will fit the rear cuz my rears are like 18x9 +20.
Old Sep 16, 2012 | 07:51 PM
Marsellus Wallace's Avatar
Guys, what about 19x9.5 ET30 up front? Would that work with just a fender roll?
Old Sep 16, 2012 | 08:58 PM
HOLLYHOOD's Avatar
need a roll and slight pull
Old Sep 16, 2012 | 09:08 PM
chaqui74's Avatar
and lets not forget you also need to run stretch tires
Old Sep 16, 2012 | 09:37 PM
HOLLYHOOD's Avatar
yup thought that one was obvious fitment takes work its not as easy as some people make it seem
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
mellsonnj
Sep 24, 2015 04:42 PM
