Need help with Zedd SL5 19x8.5 +35mm
Old 02-10-2016, 11:38 AM
5th Gear
Nuzeng's Avatar
Hey everyone, new to group and to Acura. This is my very first vehicle I own and not quiet knowledgeable with wheels. I have a 2012 Acura TSX base. Found Zedd SL5 19x8.5 with +35mm offset and want to get them but the +35 offset concerns me. Did a some research but not giving me any positive answer.
Any advice on if this size will fit? will it rub? any mods needed to fit? what tire size is preferred?
Any help would be much appreciated.
Old 02-10-2016, 11:40 AM
5th Gear
Nuzeng's Avatar
forgot to add but im lowered about 1.5" on teins.
Old 02-10-2016, 11:56 AM
Graphite Ghost
robpp's Avatar
must be 5X114.3 bolt pattern
if hub bore is more than 64.1 you need hub rings.
looks like they are 73.1 so get some from 73.1 - 64.1
last you need new tpms or move old ones/
Old 02-10-2016, 01:31 PM
5th Gear
Nuzeng's Avatar
Zedd sl5 19x8.5/5x114.3/+35 .would i need to roll my fenders? and tpms could be done at a shop if im correct?
Old 02-11-2016, 11:25 AM
PROFESSIONAL IDIOT
V-tecAc's Avatar
TPMS needs to be put on when you have your tires put on the rims. I dont have them so vsa cant be turned off but I got 9.5 inch wide wheels so the traction controll rarely chimes in even at WOT.
willtheyfit.com can help you with tire size to see the stretch if you so desire a stretch. Or look on the dropped/slammed/lowered thread Im pretty sure a lot of people are running 8.5 wide
Old 02-11-2016, 01:25 PM
5th Gear
Nuzeng's Avatar
If I decide to get 18x9.5 +22 offset instead. Would it poke out too much to the point where I got to pull the fender and camber??
Old 02-11-2016, 02:29 PM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
Yes
Old 02-12-2016, 10:00 AM
PROFESSIONAL IDIOT
V-tecAc's Avatar
Yeah roll all around and pull in the front for those specs. no matter what height you are at.
My 19x9.5 +39 needed a roll all around and a slight pull in the front to get to the ride height I am now, frame rails at 2.5 inches.
Old 03-15-2016, 11:07 AM
jam0837's Avatar
i have the same rims except +45 and no fender roll was needed, lowered about 2in on FunctionForm Coils
