Megan racing Coilover TSX
Installed coilover on my tsx and it was great.
It's been 7 months and I hear some knocking sounds at the rear. I tried to open the box that leads to the rear coilover but I have no clue what to do. People said tighten the nut? Any tips guys?
I hear knocking sounds everytime i hit over a pothole or speedbumps. If i drive normally there is no sound.
VTEC just kicked in, yo!
Yeah try tightening the bolt above the tophat. I hope by twist you don't mean you're gonna try and do this by hand... you'll need some sort of socket wrench to apply enough torque. The Megan instructions should specify the torque spec of the nut, at least my TEINs do.
I;m gonna try it tomorrow. yeah I will def need to use socket for the 17mm one. I think I can just twist the top part right (damper) ?? My rear coilover is so hard to twist the damper out.. there's so little space
On Megan;s site it tells me CCW. I'm guessing I will be doing CW to make it tighter?
Former Sponsor
"I hear knocking sounds everytime i hit over a pothole or speedbumps. If i drive normally there is no sound."
Huh, I kinda figure the occasional speed bump and pothole are pretty normal to encounter.
In our experience, when there is a knocking it is either something loose, or the shock has lots its gas pressure. Let us know how it goes!
Marcus
Marcus
Marcus
Marcus
I tried tighten it myself but I have no luck. The space provided for was too tight.....
Former Sponsor
If it has a rubber bushing honestly the bolt in there is not usually the cause of the noise. It can happen that there is creaking between the upper mount and the body. You can try dropping the damper down and putting a piece of rubber in there to try and isolate the upper hat from the underside of the body mount.
Messing with all this stuff is like a hail-mary. Most of the time the noise is inside the damper itself. We see it on the entry-level dampers like these.
It is probably a rubber upper mount, right? A rubber bushing, not a spherical bearing?
What has been the best coilover option for the 2G TSX, in terms of value/quality/ride?
Former Sponsor
PERSONALLY, Tein has been a really great brand for us. They last a long time, are refined in ride and handling, and are quite good with support after the fact. The cost is not the lowest, and you won't get all the features on paper of a Megan kit...but you do get more features than with H&R at a lower price. We feel Tein Street Basis/Street Advance/Street Flex offer the best value for the Acura driver in the business.
Might be time to come down to your shop bring the wagon, and see what you guys can do
Yeah go with TEIN, I love my set of Street Basis. I have no plans on slamming my vehicle (a modest 3" drop is more than enough for me), adjustable dampening is one thing, I decided I don't need this for my DD; no regrets, and of course TEIN quality. Just need to figure out if you need the extra features or not, then choose accordingly
^^ thank you sir
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
