Just purchased a '14 TSX and I'm nervous about some noises! HELP!
Old 07-03-2017, 12:59 PM
6th Gear
Teach1218's Avatar
Unhappy Just purchased a '14 TSX and I'm nervous about some noises! HELP!
OK, so my 04 TL just died, R.I.P., and I found a '14 TSX online at a reputable dealer (Volkswagen). I believe it was a trade in. Anyway, there was a CarFax hit (accident report, no damage reported), but I felt pretty confident considering that the car drives like a dream and the dealership assured me the frame is good. OF COURSE, the next day, I noticed some sounds coming from the rear (left side, I believe), but only when I am on a bumpy road. This has sent me into major freakout mode thinking there is something majorly wrong that I can't fix. Car drives perfectly, no pull to either side with hands off wheel or when braking. I noticed very slight negative camber on the back tires (I just learned about that yesterday woo! hoo!), but I've read that's normal. My question: the car is immaculate inside and out and drives beautifully. Could rear noise indicate a super major issue? I'm ok with shock/strut/wheel issues. I'm just really worried about chassis damage
Thank you!!!
Old 07-04-2017, 10:31 AM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
Take it to a mechanic and get it inspected if you're still worried.
You probably should've brought a mechanic to the dealership for an inspection before signing the papers, but obviously that's a moot point now. Definitely do that next time you're buying a used car though!
Good luck
Teach1218 (07-04-2017)
Old 07-04-2017, 12:49 PM
6th Gear
Teach1218's Avatar
Good luck
Yes, it was foolish of me, I know :/ I have an appointment tomorrow morning, but I'm hoping for the best. All panels are original, which is good, but I guess it could have hit a pothole or something.
Old 07-05-2017, 10:26 AM
BROlando's Avatar
Received 1,166 Likes on 877 Posts
Impossible to tell anything from this post.
Let us know how the trip to the mechanic goes!
Teach1218 (07-10-2017)
Old 07-06-2017, 08:48 AM
9th Gear
vinola's Avatar
who knows, it might be some worn out bushings
Old 07-06-2017, 09:31 AM
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
Report back with results.
Old 07-10-2017, 02:36 PM
6th Gear
Teach1218's Avatar
Thank you to all who responded. I took it to Acura this morning and they said it's just a manufacturing snafu and that they just needed to put in a wedge to stop the creaking (the creaking was coming from the left rear), The SA knew exactly what it was before they even took it to be assessed because he said he's seen it before. So, lucky me! Turns out the car really is in awesome shape! I will respond later with more specifics so that hopefully another owner can have some info if they also run into this,
Old 07-10-2017, 07:39 PM
6th Gear
Teach1218's Avatar
Ok, what they told me is that the two rear jack points were too tight and that the back end creaked because there was no give. They created a wedge at the points on each side. No more creaking, thank goodness.
Old 07-10-2017, 08:36 PM
BROlando's Avatar
That really doesn't sound right. This was an Acura dealership?
Old 07-11-2017, 08:04 AM
NBP04TL4ME's Avatar
I agree with BROlando or at the very least, I don't understand the explanation. Can you post pictures of what they did to your car and/or what the repair order says?
Old 07-11-2017, 09:10 AM
xtcnrice's Avatar
OP is describing this: https://acurazine.com/forums/2g-tsx-...r-curb-960226/
TSB: http://techinfo.honda.com/rjanisis/pubs/SB/B09-019.pdf
The following 2 users liked this post by xtcnrice:
NBP04TL4ME (07-11-2017), Teach1218 (07-17-2017)
Old 07-11-2017, 09:17 AM
NBP04TL4ME's Avatar
Thanks XTC
xtcnrice (07-12-2017)
Old 07-17-2017, 03:17 PM
6th Gear
Teach1218's Avatar
Yes, it was Acura!
Old 07-17-2017, 03:28 PM
6th Gear
Teach1218's Avatar
Smile
This is awesome, thank you so much! I had limited context, so I could only describe it in general terms (as told to me).
xtcnrice (07-18-2017)
