H&R 5mm Spacers
Old 06-15-2010 | 03:18 PM
  #41
SinCityTLX's Avatar
Looks pretty darn good. I don't plan on lowering however so I want to run a 245/40/19 tire. This should more closely match the stock diameter, if I am not mistaken and fill the wheel well better.
I have only seen one member on here witha 245/40/19 setup on HFP wheels and it looked good.
Old 06-15-2010 | 07:48 PM
  #42
DerwoodEE's Avatar
The overall diameter with a 40 tire on a 19" wheel will be larger than than stock. My tire size (245/35) I believe is the closest you can get to the stock diameter with a 19" wheel. I did a lot of research prior to ordering my wheels and tires and that was the closest found.
Old 06-15-2010 | 08:01 PM
  #43
SinCityTLX's Avatar
Well I am gonna leave it sock height and the 245/35/19 setups I've seen that had stock suspension, it looked weird because the diameter was too small. I have seen one with 245/40/19 and hfp wheels, it looked a lot better because it filled the wheel well a little better.
Old 06-17-2010 | 02:40 PM
  #44
scooterb84's Avatar
Well, just got notified that my spacers are on backorder.. so going to be a week or so.
Old 06-17-2010 | 03:02 PM
  #45
SinCityTLX's Avatar
Well that sucks, I wanted to see your car so you could be the guinea pig, lol.
Old 06-17-2010 | 03:13 PM
  #46
VdaAccord06's Avatar
i am in need of spacer myself..looking forward to your picturess
Old 06-17-2010 | 04:56 PM
  #47
scooterb84's Avatar
LOL, thank sin!
I will get the pics up as soon as they are installed. Have a good weekend everyone!
GO LAKERS!!!!
Old 06-20-2010 | 01:48 AM
  #48
SinCityTLX's Avatar
Scooter, Did you get the 5mm and 10mm spacers? or are you doing 10mm and 15mm.
From what I can tell the 5mm spacers are not hub centric. The spacer itself will rest on the hub, but the wheel will not longer have a hub to rest on.
Old 06-21-2010 | 11:08 AM
  #49
scooterb84's Avatar
No, they are backordered so just waiting for a call to say they have shipped. I did the 5mm for the front and 10mm for the back. 10mm for the front would be way to much in my opinion with the HFP wheels.
As far as the hubcentric part, I really dont know what else to say.... they quote them as hubcentric on all sites, so I guess I wont have more info for you until they come in... Everyone else says they are , so not sure what to tell ya.
Old 06-21-2010 | 01:04 PM
  #50
SinCityTLX's Avatar
It's amazing to me why products like wheel spacersare always back ordered. They take like 2 minutes to make by the gazillions on the forging press. Why not just keep the press running instaed of creating a backlog.
I am just pissed because I want to see your rig with that setup.
Old 07-10-2010 | 02:19 AM
  #51
Nammib0i's Avatar
Any update on the shipment of your spacers? I'd like to see them on your car.
Old 07-10-2010 | 02:54 AM
  #52
madeguy76's Avatar
CU4...cylinders later!
Heres my HFP's with 245/40/19's... No spacers & sits damn close to the stock ride height of my 18's.
Plus, wont you have to get yur tires re-balanced w/ said spacers?
Old 07-10-2010 | 01:27 PM
  #53
SinCityTLX's Avatar
Your rims are sick.
Old 07-11-2010 | 12:46 AM
  #54
SinCityTLX's Avatar
Do you still have your stock 18s? Would you be interested in selling them?
Old 07-11-2010 | 12:50 PM
  #55
scooterb84's Avatar
Car looks really good bro! I ended up getting just the 10mm for the rear and really like the way it turned out. Going to wash the car later and I will upload some pics.
Old 07-11-2010 | 01:38 PM
  #56
SinCityTLX's Avatar
hurry and post those pics.
Old 07-15-2010 | 11:37 AM
  #57
scooterb84's Avatar
Sorry for the delay. Still havent washed the car, but I did manage to get some Camera phone pics before and after. I will wash the car this weekend and get some nice shots to post up. Overall VERY happy with the results. They sit perfect in the rear now. I plan on getting another alignment to see if they can adjust the camber a little to reduce the top gap, but even now the rims sit perfect. Highly recommend the spacers. They were very easy to install.
Before
After
Old 07-15-2010 | 11:55 AM
  #58
scooterb84's Avatar
Here is a side shot I just took compared to an old side shot before the spacers. Sorry for the crappy pic, doesnt really do justice, but I will definitly get some better pics this weekend.
Before
After
Old 07-15-2010 | 11:58 AM
  #59
SinCityTLX's Avatar
pretty damn nice.
Old 07-15-2010 | 09:47 PM
  #60
SinCityTLX's Avatar
you also need to take some angles shots with the steering wheel striaght. It is hard to really tell how it sits if the front wheels are turned because you cant judge if they sit even or not.
Old 07-22-2010 | 01:37 PM
  #61
scooterb84's Avatar
No problem. Got the car cleaned, so I will take some more shots today.
Old 01-23-2016 | 12:27 PM
  #62
jobro's Avatar
Bringing this one back from the dead:
Scooter, did you do extended studs in the rear for the 10mm spacers? And if so, did it require removing the wheel hubs? Or just pulling the brake rotor off and hammering the old ones out then dropping the new ones in? I can't find a definitive answer in the forums, so I figured I'd ask since I want to do the same thing.
Thanks!
Old 01-25-2016 | 10:51 AM
  #63
scooterb84's Avatar
Thanks!
It was simple, just hammed the old ones and put the new longer ones in. The front however was going to require taking the rotor off which is why I went with the 5MM.
Old 01-25-2016 | 11:25 AM
  #64
jobro's Avatar
Awesome, thanks! That's good news, since I ordered my spacers last night haha
CL-S progression 01
01-26-2016 04:15 PM
rockvilleTL
09-19-2015 04:44 PM
yvr_tsx
09-15-2015 01:14 PM
Quick Reply: H&R 5mm Spacers
