fitment question
Old Feb 27, 2014 | 12:14 PM
SQUEEZY83's Avatar
fitment question
Hello I tried using the rim calculator but its confusing to me. Im interested in purchasing some wheels that I found. The wheels are 19x8.5 ET35 whats the best recommended tire to go with. I was looking at 245/45r19 seems that according to the calculator this is too big a variance from stock?? This tire size seems to be in stock at a lot more places and gives me more options. I want a decent tire no capital sports or some unknown brand. im going to be putting these wheels on a 2012 TSX sportwagon on stock height and I want to have as much rubber as I can get without having any problems. I may drop the car in the future an inch or so but not right away so what are your guys suggestions?
Old Feb 27, 2014 | 12:21 PM
the stock tire configuration is 225/50/17
you want to keep the same rolling diameter.
a 245/35/19 tire would keep the same rolling diameter by .41%
Old Feb 27, 2014 | 12:24 PM
you could use the 245/45/19's if you really wanted to, but it would be 7% taller.
which would mean your speedometer would be 7% faster
Old Mar 17, 2014 | 06:07 AM
biggamejk's Avatar
i have 19x8.5 +35 with 225/45 and fits juuuust right at front and rear without fenders being rolled... good luck... I wanted to get 245/35 but I know it would rub both front a rear without a doubt
Old Mar 21, 2014 | 07:19 AM
Puppetmaster's Avatar
I am highly opposed to aftermarket wheels with no drop, especially 19s, I'd rather drop first on stockers than do that. But since you say you might get a drop later, I'd go with the size closest to OEM specs, what JustnSpace said initially: 245/35/19. Any larger and you will run into other fitment issues if you do decide to get springs later on, especially with that rim width and offset.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
