2013 TSX SE on H&R coilovers and RDX wheels......
Old Aug 24, 2013 | 08:18 PM
SinCityTLX's Avatar
I just installed the new coilovers because I was bored with the stock suspension
Old Aug 24, 2013 | 09:45 PM
Honda_boy83's Avatar
Looks good, how much are you dropped?
Old Aug 24, 2013 | 09:53 PM
Rdub81's Avatar
Nice job, looks good!
Old Aug 24, 2013 | 11:22 PM
08r3308's Avatar
i tough you had tein ss, any pics of h&r?
are h&r they better?
Old Aug 25, 2013 | 11:39 AM
bad_bwoy007's Avatar
Wow. Looks good!
Old Aug 25, 2013 | 03:40 PM
SinCityTLX's Avatar
No pics of the coilovers, I forgot to take them. They are not adjustable, but ride well, very similar to the Teins. The only bad thing with the H&r is they use a cheap plastic washer that the spring rests on between the coil and the adjustment collar. I can see after a while it will wear out. They should have used aluminum.
The H&r progressive coils feel better than the Teins. And the rebound could be a bit stiffer, but the compression damping is very good. A great coilover for under $1000.
Old Aug 25, 2013 | 03:55 PM
stan_t's Avatar
H&R coilovers are based on Bilstein inverted mono-tube shocks, which can be argued to be a better shock than what Tein uses. Good choice IMO. Looks great.
Stan
Old Aug 25, 2013 | 06:23 PM
terdonal's Avatar
Looks great.
Old Sep 3, 2013 | 02:53 PM
SinCityTLX's Avatar
Stan
I would say the H&R are better than teins, especially for the price.
Old Sep 16, 2013 | 11:50 PM
PPower's Avatar
I was very close to getting H&R for the inverted tube shock and progressive rate springs, but I felt like I needed more adjustability with the extra rear weight of the wagon. For a sedan, H&R is a very under-used set for this car. It looks great.
Old Sep 18, 2013 | 01:25 AM
SinCityTLX's Avatar
Thanks for the compliment. However my H&R have more adjusment range than my Teins did. The springs non my Teins seemed too short as you needed to adjust the collar up 60% of the way to get it to engage with the coil. It is dangerous to not have some preload on the coil.
I would definately say the H&R coilovers are better than the Teins, not by a lot, but for being cheaper as well they are a great decision.
However I did love my Teins also.
Old Sep 18, 2013 | 01:39 PM
stan_t's Avatar
The Bilsteins in the H&R kit are much nicer than whatever Tein uses, no argument there. I was seriously considering the H&R kit but went with KONIs, mostly because of the spring selection and the fact that I could run stock springs if needed.
Stan
jriv7
May 8, 2020 05:50 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
BoricuaTL
Apr 8, 2016 01:08 PM
vbgregg
Sep 11, 2015 05:38 PM
kuzdu
Sep 10, 2015 08:42 PM
