19x9.5 +22 235/35r19 possible?? guys with low offset please help!
i have seen people running 19x9.5 +30 with 235/35r19
the wheels i want only comes in +22, will i rub or hit my fender during turns?? i am slammed on coilover!!
guys with low offset wheel on the front pls help!
problem is my wife will be driving this car while i am out town... and i cant say no to that
my ride height is similar to ttk's white se, hes running 9.5+30 and 235 tires, and with +22 is only 7mm more then what he has, will i rub or hit the fenders go thru speed bump at an angle? will it ever touch anything after i pull shave and roll??
now the question is does your wife know how to drive a car that is looow?
its "only" 8mm but when it comes to car fitment thats a lot im running 9" et35 with 225/35 tire and i was rubbing pretty badly at first but after roll and slight pull dont have problems anymore and my front camber was adjust to spec didnt want run camber up front
I'm running 19x9.5 et 22 rear...225/35....rolled fenders and 3degrees of camber is a must....fronts with those specs would poke 8mm and rub like shit....9.5et 30 is flush in the front...wouldn't do et22 if I were u....in the front I mean...
https://acurazine.com/forums/2g-tsx-tires-wheels-suspension-300/rolled-pulled-shaved-low-858227/
from this thread, he's only running 2-2.5 camber at the back and he has plenty of space at the back!
and for the looks of it, 8mm more in the front is not that bad!!
My rears are 9.5 +45 but I also threw on +25mm spacers so basically running a +20. +22 should work with roll and slight pull. I'm also on a 235 tire. As for the front, your gonna be looking at a little more work to fit.
1fatcrxnem1
22
06-01-2018 01:23 AM
nuldabz
09-03-2015 05:49 PM
