valve lash specs?
Old Mar 27, 2016 | 06:19 PM
TimmyTang's Avatar
8th Gear
valve lash specs?
Well, I will be pulling off my valve cover to change out the gaskets since I found a leak. Figured I'd adjust the valves. So I've been searching and from my research the clearance should be intake .21-.25 and exhaust .25-.29. I just wanted to confirm before I start doing the adjustments.
Thanks!
Old Mar 27, 2016 | 07:22 PM
ulrblitzer's Avatar
You are spot on.
From the service manual:
Valve Clearance(cold)
Intake 0.21 - 0.25mm (0.008 - 0.010in.)
Exhaust 0.25 - 0.29mm (0.010 - 0.011in.)
Old Mar 28, 2016 | 06:23 AM
ssjoeboe9's Avatar
ROTAREDOM
Someone else posted about this not too long ago. I posted a picture of the service manual. I also agree with what you guys posted.
Can you also tell us how many miles you have on the car and how far out of tolerance each valves were? I never did mine at the 100K mile mark. Im also curious to know if it idles a little quieter when you have the hood open.
Old Mar 30, 2016 | 10:22 AM
TexasHonda's Avatar
Good time to replace valve cover gasket and spark plug tube seals.
good luck
Old Apr 3, 2016 | 12:23 PM
TimmyTang's Avatar
8th Gear
Thanks. I am rolling up on 120k. Changed spark plugs just before 100k mark. Parts should be here on Tuesday.
PrimeTimeTSA
Feb 23, 2016 10:08 PM
balistek
Feb 9, 2016 03:27 PM
Bryan_JDM
Feb 9, 2016 07:23 AM
