torque specs
Old Oct 6, 2011 | 04:16 PM
robm's Avatar
torque specs
I'm looking for the torque specs for the front brakes on an '09. Could someone please post them, or point me to a thread that might have them? I did a search, but turned up nothing. Thanks
Old Oct 6, 2011 | 04:47 PM
hohos's Avatar
8th Gear
I found this service bulletin that csmeance posted:
https://acurazine.com/forums/2g-tsx-2009-2014-143/2nd-gen-tsx-tsb-information-789358/
I've also attached the pdf, if you don't want to go through the link.
In it, it states that the bottom flange bolt of the calipers should be torqued to 50N-m or 37ft-lb, and the brake hose mounting bolt should be torqued to 22N-m or 16ft-lb. I think taking the latter bolt off is unnecessary for changing the brake pads. However, I recommend taking that off if you are going to unbolt the whole caliper for changing the rotors.
Hope this helps.
File Type: pdf
Old Oct 6, 2011 | 06:26 PM
robm's Avatar
Awesome, thank you!
08KBP_VA
Oct 22, 2019 01:55 PM
emailnatec
29
Sep 28, 2018 04:27 PM
jsonkimz
Mar 28, 2016 07:49 PM
knight rider
Mar 4, 2016 08:59 AM
Tribalheads
Sep 29, 2015 03:24 PM
