Side mirror adjusting issues! Need help!
Hey guys/girls. For starters this is my first post!
i have a 2nd gen tsx
i bought it knowing that the side mirrors have a little bit of a problem though. The driver side mirror can adjust but it does not angle down in reverse. The passenger DOES angle down but it cannot be adjusted from the control panel.
What could be the issue? And how can i fix it? Thanks!
i have a 2nd gen tsxi bought it knowing that the side mirrors have a little bit of a problem though. The driver side mirror can adjust but it does not angle down in reverse. The passenger DOES angle down but it cannot be adjusted from the control panel.
First of all, the driver's side mirror is not designed to angle downward in reverse. Second, make sure the sliding switch is pushed to the side you are adjusting. If it is not, that mirror will not move at all. Hope this helps!
Thanks, i thought i seen someone on youtube with both mirrors angling down in reverse. And i had the sliding switch pushed to R. Still nothing
Frosty
Apr 13, 2021 01:13 PM
ed_423
Aug 2, 2012 12:33 PM
GTkim83
Nov 29, 2008 12:08 PM
