Service Bulletins
not really... you need to describe the symptoms to them, then they have to be able to reproduce it. THEN they may determine that the TSB applies, and will perform it. Most techs are competent and will do it if the TSB will really solve your issue...
^ I suggest that you make an appointment and show the service adviser your car and moldings. I don't think it's a challenging issue to diagnose, so they should be able to fix it using (probably) the TSB for it.
it's a car-drive it
tsb's are covered while the car is under warranty-after the warranty they can charge you to fix the problem. If you have a good relationship with the acura dealer they might not charge you or fix it at a discount. There was a TSB on the wipers on the tsx-the dealer replaced mine free even tho the warranty on my car was long gone.
Service bulletin
I have a 2009 Acura TSX and my Front brakes are squeaking. I emailed my Acura dealer about service bulletin for the brakes. They told me they are no known recalls or service bulletin for my car because they looked up my Vin
Number. Are service bulletins for certain 2009 TSX?
7# werC 2uoYeeS
Bottom line proper procedure is to make an appointment for your concern have it diagnosed. Theres no way to say yes or no until the vehilce is looked at by a tech to confirm or deny a guest's complaint.
