Right Fog light
Old Feb 8, 2011 | 02:54 AM
LBTSX09's Avatar
Right Fog light
Hey guys,
So I was going to swap out my HID bulb to 4300k the other day because i thought it was the bulb that was out, but when I put in the new bulb still did not work. The other side works fine. I also went and took the HID's off on that side and replaced it with the OEM bulb still didn't work. Can someone tell me what going on? Did I burn the wiring? or something?
P.S.
I noticed on the low beams one reflects higher than the other. Is there a way to adjust them so they are even?
Best,
LBTSX09
Old Feb 8, 2011 | 10:40 AM
saucy's Avatar
Is it your driver side that is lower? Mine is the same way. I am not sure if this is adjustable from stock set up. I believe they do this so that we do not blind oncoming traffic and so that on passenger side, it will shine further into distance. Just my thoughts though. I know in my civic I created my own custom HID projector setup and I had a very level cuttoff and I got flashed quite a bit. So, I lowered my driver side some.
Old Feb 8, 2011 | 10:45 AM
the step that you see in the beam pattern is there for a reason as to not blind oncoming traffic.
as for your problem, it might be a ballast. switch ballast and see if the problem follows it.
Old Feb 8, 2011 | 12:00 PM
KillerG's Avatar
Op is too busy to care
switch ballasts. are you talking about fogs or lows?
Old Feb 14, 2011 | 09:43 PM
LBTSX09's Avatar
I'm talking about the fogs.
Old Feb 14, 2011 | 09:47 PM
TSXKid2010's Avatar
SEEYOU2CREW
If it's fog, he tried the stock on both sides, then it can't be a ballast...right?
There's no way that that bulb can be dead already...right...?
I say bring it to the dealership. Must be a deeper problem.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
