Rear Passenger Rattle Diagnosis and Fix
Well, I was driving home today as usual and this time i turned the radio off to see if I could hear an engine rattle as described in a different thread. I did hear a very faint raspy rattle when getting on the gas but I assumed it to be normal.
Instead I heard a different rattle. Just on little bumps and grooves in the road. It sounded like it was coming from the rear passenger side. So i was like, "eh, ill take it in to get check sometime". I kept wondering what it was and I thought, sunroof shade. I did lower all the windows/sunroof as i was walking to the car to air out the hot air but then closed them after I started the car and AC.
I closed the shade and the rattle went away.
Another rattle that some of you may hear up front ithat will drive you crazy is if you have sunglasses in the holder up top. It took me a month to locate that rattle. The fix is to either put some padding in there (like Acura should have done), or just don't put glasses in there.
3GTLOwns
Sep 9, 2015 09:51 PM
