OEM Wiper Blade Refills
Hi, I just signed up to pass something along that might help a 2G TSX owner. If you still have your original hard plastic wiper blades which use 10m thick replacement rubber refills, you can only get these refills at the dealer AFAIK. To that point, the part numbers are:
DRIVER SIDE: 76622-SLN-A12 Rubber, Blade (600MM)
PASSENGER SIDE: 76632-SHJ-A12 Rubber, Blade (550MM) - Acura only
The driver side refill can be purchased at a Honda dealer as well as Acura however the passenger side is an Acura exclusive part number. As I don't like to drive a lot farther to the Acura dealership, I buy everything possible from the closer Honda dealer. I found a perfect cross reference for the identical passenger refill, it fits 2008- 2010 Odyssey and the HONDA part number is:
76632-SHJ-A11 Rubber, Blade (550MM) - Honda only
I've installed it and can find no difference. Maybe there's a slight material difference not visible to the naked eye but it works fine. I much prefer this type of wiper blade to the metal frame or beam type aftermarket options. HTH.
Update 08/21
