Just debadged my Grigio 2010..!!!
I Still seem to be able to see marks from the letters After I've waxed it....I don't want to use a power buffer anyone know of ways to make them go away??? ScratchX??
Unregistered Member
Goo gone. Or Goofoff. Or something similar.
ScratchX works the same way as a buffer, except you use your hand instead of a buffer.
Just remember to use a paint sealant or good wax afterwards.
![BEETROOT](https://acurazine.com/forums/images/smilies/lift.gif)
That said, Harper brought up a good point that you may still have some residue left from the glue, but you should be albe to feel that.
Part of the issue is also that the clearcoat over the exposed paint will have weathered. A good detailer (using power equipment) should be able to polish the entire area and blend the "new" finish (under the letters) with the weathered finish.
Me? I'd spring for a full detail with minor paint correction and get the whole car looking like the area under the letters.
If it is a 2010 then the areas not covered by the letters have been exposed to the elements for several years and the paint has faded so you may always see a slight difference.
Over time your finish aquires hairline scratches and swirls that slightly haze the clearcoat. Since it happens slowly over time and evenly over the car you don't notice it - until you expose an unweathered area like under the letters.
Unregistered Member
Yeah, pretty much what ceb said. Paint around the badges has slightly discolored from age/rain/elements/etc and the paint under the badges is still factory condition. You're more than likely going to need a full detail with slight paint correction.
Unregistered Member
There's plenty of how to videos on youtube, and there's how to's on detailing blogs etc. Check out detailedimage.com's blog, they have plenty of good info.
Every black car I have debadged looked exactly like that, regardless of age. You are going to need a good polish. I would suggest either Meguiars M101 or M201 or both, then finish off with a good sealant.
The M201 should be enough, it normally is. You just need to even the clear coat around the area.
I took the side moldings off of a GMC Z71 years back and used that 3M wheel, it was a freaking life saver at the time, but it's a bit overkill when just debadging. I burned through 2 DeWalt batteries on my drill doing it as well, but the look was great afterwards.
Good luck.
Good luck.
TLDude876
12-28-2016 03:18 PM
