Error code PO705
Old Jul 19, 2015 | 08:50 AM
Benzeno's Avatar
Error code PO705
Hey all, This code popped up the other day on our 2010 TSX. I have searched the forums, but haven't come up with a TSX specific solution. I've read that it could be the Neutral Safety Switch/Range Sensor. The Check Transmission light is on, and the D light is blinking. Cannot use paddles in D. Has anyone had this issue, and come up with a fix? Any tips would be appreciated! B
Old Jul 27, 2015 | 12:11 PM
t3hhcaptain's Avatar
Sounds like a bad sensor.
P0705 Acura Short In Transmission Range Switch Circuit OBDII Engine Light Trouble Code | Engine-Codes.com
P0705 Transmission Range Sensor Circuit Malfunction (PRNDL input)
#20 OEM Acura TSX SEDAN 2010 AT LEFT SIDE COVER parts
Not sure if this is the issue or not, but #20 on the diagram appears to be the item that the obd code is talking about...
Best of luck.
Edit: see this - https://acurazine.com/forums/third-g...switch-892223/
Old Jul 29, 2015 | 08:43 PM
Benzeno's Avatar
Best of luck.
Thanks for the reply. I saw that video, and it is helpful. TSX cant be much different. I took the car to my mechanic today and paid for 1/2 hour of diagnosis. He said its most likely the Range sensor, and to start with that. For 75 bucks its worth a shot. I will post up results, and maybe take some pics.
Old Aug 6, 2015 | 12:47 PM
Any updates?
Old Aug 7, 2015 | 05:21 PM
Benzeno's Avatar
Yes, I bought a new Neutral safety switch from rock auto for 84 bucks shipped, and it took me probably 15 minutes to install. Piece of cake! Check engine light went out the next day, and its back to normal. The switch is right there under a cover when you remove the drivers side wheel. 5 10mm bolts and a plug and its out. I got this DeWalt 18 volt 1/2 in impact driver for christmas, and it has paid for itself already, doing F and R brakes and now the switch.
Old Aug 8, 2015 | 10:08 PM
Glad to hear it worked out for you!
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
